4.525 rtrv-lg-engine
Use this command to retrieve and display LG engine provisioning, as well as the total number of engines configured. The command class is TKLC_INTERNAL inheriting properties of DEBUG class. The Load Generator is supported on IPSG, IPLHC, IPGHC and SS7HC GPLs.
Parameters
engine (optional)
LG Engine name
Range:
ayyyyyyyyy
Up to 10 alphanumeric characters; the first character must be a letter.
Example
rtrv-lg-engine
rtrv-lg-engine:engine=rxengine1
Dependencies
The value specified for the engine parameter must already exist in the LG Engine table.
The LG Engine table is corrupt or cannot be found.
Output
rtrv-lg-engine
    tekelecstp 09-04-29 18:15:20 EST  xx.x.x-xx.x.x
    LG Engine Configuration
    TX Engine(s)
                               ENGINE                      EVENT
    ENGINE     LOC  EVENT      PORT RATE ACTION RXENGINE   DIR TYPE CLASS
    txengine1  1302 isuptx1    A    100  NONE   -          TX  MSU  INT
    rxengine1  1302 isuprx1    -    -    SNK    -          RX  MSU  -
    RX Engine(s)
                               ENGINE                      EVENT
    rxengine2  1304 isuprx2    -    -    SNK    -          RX  MSU  -
    rxengine3  1305 isuprx2    -    -    SNK    -          RX  MSU  -
    LG Engine table is (4 of 2048) 1% full
    Command Completed.
This example displays the output for a specified LG Engine.
                               ENGINE                      EVENT
    Command Completed
