4.2.4 Platform Menu
The Platform Menu allows the user to perform various platform-related functions, including running health checks, listing processes, viewing logs, and rebooting the MPS.
Figure 4-30 Platform Menu
Platform Menu
The Platform menu provides these actions:
4.2.4.1 Run Health Check
The Platform / Run Health Check screen allows the user to execute the health check routine on the selected ELAP. Alarms and Maintenance for ELAP describes the health check, which is also called system health check and syscheck, in detail.
The first screen presented in the workspace frame lets the user select the normal or verbose mode of output detail.
The ELAP system health check utility performs multiple tests of the server. For each test, checks and balances verify the health of the MPS server and platform software. Refer to Alarms and Maintenance for ELAP for the functions performed and how to interpret the results of the normal outputs.
4.2.4.2 List All Running Processes
The Platform / List All Running Processes screen lists all processes running on the selected ELAP. The /bin/ps auxw command generates this list. The operating system's manual page for the ps command thoroughly defines the output for this command. Figure 4-31 shows an example of the process list.
Figure 4-31 List All Running Processes Screen
img/c_platform_menu_elapgui_elapadmin-fig5.jpg
The exact processes shown here will not be the same on your ELAP servers. The output from this command is unique for each ELAP, depending on the ELAP software processes, the number of active ELAP user interface processes, and other operational conditions.
4.2.4.3 View System Log
The Platform / View System Log screen allows the user to display the System Log. Each time a system maintenance activity occurs, an entry is made in the System Log. When the user chooses this menu selection, the View the System Log screen appears.
Figure 4-32 View the System Log Screen
4.2.4.4 Reboot the MPS
The Platform / Reboot the MPS screen allows the user to reboot the selected ELAP. All ELAP software processes running on the selected ELAP are shut down normally.
When you click the Reboot MPS button, a cautionary message appears, informing the user that this action causes ELAP to stop all activity and to prevent the RTDB from being updated with new subscriber data.
When you are certain that you want to reboot, click the Continue button. Another screen informs you that MPS is being rebooted and that the User Interface will be reconnected when the reboot is completed.
