5 Platform and Application Alarms
This chapter provides recovery procedures for platform and application alarms related to the E5-APP-B.
Alarm Categories
This chapter describes recovery procedures to use when an alarm condition or other problem exists on the MPS system. For information about how and when alarm conditions are detected and reported, see Detecting and Reporting Problems.
When an alarm code is reported, locate the alarm in Platform and Application Alarms. The procedures for correcting alarm conditions are described in Platform and Application Alarms.
Sometimes the alarm string may consist of multiple alarms and must be decoded in order to use the Alarm Recovery Procedures in this manual. If the alarm code is not listed, see Decode Alarm Strings.-
Critical Platform Alarms
Critical Application Alarms
Major Platform Alarms
Major Application Alarms
Minor Platform Alarms
Minor Application Alarms
Table 5-1 shows the alarm numbers and alarm text for all alarms generated by the MPS platform and the ELAP application. The order within a category is not significant. Some of the alarms described in this chapter are not available with specific configurations.
Table 5-1 Platform and Application Alarms
MPS Alarm Recovery Procedures
This section provides recovery procedures for the MPS and ELAP alarms, listed by alarm category and Alarm Code (alarm data string) within each category.
Critical platform alarms are issued if uncorrectable memory problems are detected.
1000000000002000 - Uncorrectable ECC Memory Error
This alarm indicates that chipset has detected an uncorrectable (multiple-bit) memory error that the Error-Correcting Code (ECC) circuitry in the memory is unable to correct.
Recovery
- Contact My Oracle Support to request hardware replacement.
1000000000008000 – Server NTP Daemon lost NTP synchronization for extended time
Alarm Type: TPD
Description: This alarm indicates that a TPD syscheck test determined that the time last synchronized with an NTP server has exceeded the critical threshold (LAST_SYNCHRONIZED_TIME_PERIOD_CRITICAL), as configured by the application.
Severity: Critical
Alarm ID: TKSPLATCR16
Recovery
Contact My Oracle Support.
1000000000010000 – Server's time has gone backwards
Alarm Type: TPD
Description: This alarm indicates that syscheck determined that a server's time has gone backwards.
Severity: Critical
Alarm ID: TKSPLATCR17
Recovery
This section describes the critical application alarms.
2000000000000001 - LSMS DB Maintenance Required
This alarm indicates that database maintenance is required.
Recovery
- Call My Oracle Support for assistance.
Major platform alarms involve hardware components, memory, and network connections.
3000000000000001 – Server fan failure
Alarm Type: TPD
Description: This alarm indicates that a fan on the application server is either failing or has failed completely. In either case, there is a danger of component failure due to overheating.
Description: This alarm indicates that a fan in the EAGLE fan tray in the EAGLE shelf where the E5-APP-B is "jacked in" is either failing or has failed completely. In either case, there is a danger of component failure due to overheating.
Severity: Major
OID: TpdFanErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.1
Alarm ID: TKSPLATMA13000000000000001
Recovery
3000000000000002 - Server Internal Disk Error
This alarm indicates that the server is experiencing issues replicating data to one or more of its mirrored disk drives. This could indicate that one of the server disks has failed or is approaching failure.
Recovery
3000000000000008 - Server Platform Error
This alarm indicates a major platform error such as a corrupt system configuration or missing files, or indicates that syscheck itself is corrupt.
Recovery
3000000000000010 - Server File System Error
This alarm indicates that syscheck was unsuccessful in writing to at least one of the server file systems.
Recovery
3000000000000020 - Server Platform Process Error
This alarm indicates that either the minimum number of instances for a required process are not currently running or too many instances of a required process are running.
Recovery
- Contact My Oracle Support for recovery procedures.
3000000000000080 - Server Swap Space Shortage Failure
This alarm indicates that the server’s swap space is in danger of being depleted. This is usually caused by a process that has allocated a very large amount of memory over time.
In order for this alarm to clear, the underlying failure condition must be consistently undetected for a number of polling intervals. Therefore, the alarm may continue to be reported for several minutes after corrective actions are completed.Recovery
3000000000000100 - Server provisioning network error
Alarm Type: TPD
The interface identified as eth01 on the hardware is identified as eth91 by the software (in syscheck output, for example).Severity: Major
OID: TpdProvNetworkErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.9
Alarm ID: TKSPLATMA93000000000000100
Recovery
- Perform the following substeps to verify that the network configuration is correct.
- Verify that a customer-supplied cable labeled TO CUSTOMER NETWORK is securely connected to the appropriate server. Follow the cable to its connection point on the local network and verify this connection is also secure.
- Test the customer-supplied cable labeled TO CUSTOMER NETWORK with an Ethernet Line Tester. If the cable does not test positive, replace it.
- Have your network administrator verify that the network is functioning properly.
- If no other nodes on the local network are experiencing problems and the fault has been isolated to the server or the network administrator is unable to determine the exact origin of the problem, contact My Oracle Support.
3000000000000200 – Server Eagle Network A error
Alarm Type: TPD
Description: This alarm is generated by the MPS syscheck software package and is not part of the TPD distribution.
If these three alarms exist, the probable cause is a failed mate server.-
3000000000000200-Server Eagle Network A Error
3000000000000400-Server Eagle Network B Error
3000000000000800-Server Sync Network Error
One or both of the servers is not operational.
One or both of the switches is not powered on.
The link between the switches is not working.
The connection between server A and server B is not working.
The eth01 interface (top ethernet port on the rear of the server) connects to the customer provisioning network.
The eth02 interface (2nd from top ethernet port on the rear of the server) connects to port 3 of switch A.
The eth03 interface (2nd from bottom ethernet port on the rear of the server) connects to port 3 of switch B.
The eth04 interface (bottom ethernet port on the rear of the server) connects to port 5 of switch A
The interfaces on the switch are ports 1 through 20 (from left to right) located on the front of the switch.
Ports 1 and 2 of switch A connect to ports 1 and 2 of switch B.
Ports 7 to 24 of switch A and ports 5 through 24 of switch B can be used for links to the Main SM ports (SM A ports) on the EAGLE.
Severity: Major
OID: 1.3.6.1.4.1.323.5.3.18.3.1.2.10
Alarm ID: TKSPLATMA103000000000000200
Recovery
3000000000000400 – Server Eagle Network B error
Alarm Type: TPD
If these three alarms exist, the probable cause is a failed mate server.- 3000000000000200-Server Eagle Network A Error
- 3000000000000400-Server Eagle Network B Error
- 3000000000000800-Server Sync Network Error
- One or both of the servers is not operational.
- One or both of the switches is not powered on.
- The link between the switches is not working.
- The connection between server A and server B is not working.
- The eth01 interface (top ethernet port on the rear of the server) connects to the customer provisioning network.
- The eth02 interface (2nd from top ethernet port on the rear of the server) connects to port 4 of switch A.
- The eth03 interface (2nd from bottom ethernet port on the rear of the server) connects to port 4 of switch B.
- The eth04 interface (bottom ethernet port on the rear of the server) connects to port 6 of switch A.
- The interfaces on the switch are ports 1 through 20 (from left to right) located on the front of the switch.
- Ports 1 and 2 of switch A connect to ports 1 and 2 of switch B.
- Ports 7 to 24 of switch A and ports 5 through 24 of switch B can be used for links to the Main SM ports (SM A ports) on the EAGLE.
Severity: Major
OID: 1.3.6.1.4.1.323.5.3.18.3.1.2.11
Alarm ID: TKSPLATMA113000000000000400
Recovery
3000000000000800 – Server Sync network error
Alarm Type: TPD
The sync interface uses eth03 and goes through switch B. All pairs are required.Severity: Major
OID: 1.3.6.1.4.1.323.5.3.18.3.1.2.12
Alarm ID: TKSPLATMA123000000000000800
Recovery
- Verify that both servers are booted up by ensuring that the POWER LEDs on both servers are illuminated green.
- If the problem persists, contact My Oracle Support.
3000000000001000 - Server Disk Space Shortage Error
This alarm indicates that one of the following conditions has occurred:
A file system has exceeded a failure threshold, which means that more than 90% of the available disk storage has been used on the file system.
More than 90% of the total number of available files have been allocated on the file system.
A file system has a different number of blocks than it had when installed.
Recovery
- Run
syscheck(see Running syscheck Through the ELAP GUI). - Examine the syscheck output to determine if the file system
/var/TKLC/epap/free/var/TKLC/elap/freeis low on space. If it is, continue to the next step; otherwise go to 4. - If possible, recover space on the free partition by deleting unnecessary files:
3000000000002000 - Server Default Route Network Error
This alarm indicates that the default network route of the server is experiencing a problem. Running syscheck in Verbose mode will provide information about which type of problem.
Caution:
When changing the network routing configuration of the server, verify that the modifications will not impact the method of connectivity for the current login session. The route information must be entered correctly and set to the correct values. Incorrectly modifying the routing configuration of the server may result in total loss of remote network access.Recovery
3000000000004000 - Server Temperature Error
Alarm Type: TPD
Description: The internal temperature within the server is unacceptably high.
Severity: Major
OID: TpdTemperatureErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.15
Alarm ID: TKSPLATMA153000000000004000
Recovery
3000000000008000 - Server Mainboard Voltage Error
This alarm indicates that at least one monitored voltages on the server mainboard is not within the normal operating range.
Recovery
- Contact My Oracle Support for assistance.
3000000000010000 - Server Power Feed Error
This alarm indicates that one of the power feeds to the server has failed.
Recovery
3000000000020000 - Server Disk Health Test Error
This alarm indicates that the hard drive has failed or failure is imminent.
Recovery
- Immediately contact My Oracle Support for assistance with a disk replacement.
3000000000040000 - Server Disk Unavailable Error
This alarm indicates that the smartd service is not able to read the disk status because the disk has other problems that are reported by other alarms. This alarm appears only while a server is booting.
Recovery
- Perform the recovery procedures for the other alarms that accompany this alarm.
3000000000080000 - Device Error
This alarm indicates that the offboard storage server has a problem with its disk volume filling.
Recovery
3000000000100000 - Device Interface Error
This alarm indicates that the IP bond is either not configured or not functioning.
Recovery
3000000000200000 - Correctable ECC Memory Error
This alarm indicates that chipset has detected a correctable (single-bit) memory error that has been corrected by the Error-Correcting Code (ECC) circuitry in the memory.
Recovery
3000000400000000 - Multipath device access link problem
Alarm Type: TPD
Description: One or more "access paths" of a multipath device are failing or are not healthy, or the multipath device does not exist.
Severity: Major
OID: TpdMpathDeviceProblemNotify1.3.6.1.4.1.323.5.3.18.3.1.2.35
Alarm ID: TKSPLATMA353000000400000000
Recovery
- My Oracle Support should do the following:
- Contact My Oracle Support.
3000000800000000 – Switch Link Down Error
This alarm indicates that the switch is reporting that the link is down. The link that is down is reported in the alarm. For example, port 1/1/2 is reported as 1102.
Recovery Procedure:
- Verify cabling between the offending port and remote side.
- Verify networking on the remote end.
- If problem persists, contact My Oracle Support to verify port settings on both the server and the switch.
3000001000000000 - Half-open Socket Limit
Alarm Type: TPD
Description:This alarm indicates that the number of half open TCP sockets has reached the major threshold. This problem is caused by a remote system failing to complete the TCP 3-way handshake.
Severity: Major
OID: tpdHalfOpenSocketLimit 1.3.6.1.4.1.323.5.3.18.3.1.2.37
Alarm ID: TKSPLATMA37 3000001000000000
Recovery
3000002000000000 - Flash Program Failure
Alarm Type: TPD
Description: This alarm indicates there was an error while trying to update the firmware flash on the E5-APP-B cards.
Severity: Major
OID: tpdFlashProgramFailure 1.3.6.1.4.1.323.5.3.18.3.1.2.38
Alarm ID: TKSPLATMA383000002000000000
Recovery
3000004000000000 - Serial Mezzanine Unseated
Alarm Type: TPD
Description:This alarm indicates the serial mezzanine board was not properly seated.
Severity: Major
OID: tpdSerialMezzUnseated 1.3.6.1.4.1.323.5.3.18.3.1.2.39
Alarm ID: TKSPLATMA393000004000000000
Recovery
3000000008000000 - Server HA Keepalive Error
This alarm indicates that heartbeat process has detected that it has failed to receive a heartbeat packet within the timeout period.
Recovery
- Determine if the mate server is currently operating. If the mate server is not operating, attempt to restore it to operation.
- Determine if the keepalive interface is operating.
- Determine if heartbeart is running (service TKLCha status).
3000000010000000 - DRBD block device can not be mounted
This alarm indicates that DRBD is not functioning properly on the local server. The DRBD state (disk state, node state, or connection state) indicates a problem.
Recovery
3000000020000000 - DRBD block device is not being replicated to peer
This alarm indicates that DRBD is not replicating to the peer server. Usually this alarm indicates that DRBD is not connected to the peer server. A DRBD Split Brain may have occurred.
Recovery
3000000040000000 - DRBD peer needs intervention
This alarm indicates that DRBD is not functioning properly on the peer server. DRBD is connected to the peer server, but the DRBD state on the peer server is either unknown or indicates a problem.
Recovery
3000020000000000 - Server NTP Daemon never synchronized
Alarm Type: TPD
Description: This alarm indicates that the NTP sync file (/var/TKLC/log/syscheck/ntp_sync_config) and the NTP last known good time file (/var/TKLC/log/syscheck/ntp_last_good_time) have not been synchronized.
Severity: Major
Alarm ID: TKSPLATMA42
Recovery
The major application alarms involve the ELAP software, RTDBs, file system, and logs.
4000000000000001 - Mate ELAP Unavailable
One ELAP has reported that the other ELAP is unreachable.
Recovery
4000000000000002 - RTDB Mate Unavailable
The local ELAP cannot use the direct link to the Standby for RTDB database synchronization.
Recovery
4000000000000004 - Congestion
The ELAP RTDB database record cache used to keep updates currently being provisioned is above 80% capacity.
Recovery
4000000000000008 - File System Full
This alarm indicates that the server file system is full.
Recovery
4000000000000010 - Log Failure
This alarm indicates that the system was unsuccessful in writing to at least one log file.
4000000000000040 - Fatal Software Error
A major software component on the ELAP has failed.
Recovery
- Perform Restarting the ELAP Software
- Capture the log files on both ELAPs (see Saving Logs Using the ELAP GUI) and contact My Oracle Support.
4000000000000080 - RTDB Corrupt
A real-time database is corrupt. The calculated checksum did not match the checksum value stored for one or more records.
Recovery
4000000000000100 - RTDB Inconsistent
The real-time database for one or more Service Module cards is inconsistent with the current real-time database on the Active ELAP fixed disks.
Recovery
4000000000000200 - RTDB Incoherent
This message usually indicates that the RTDB database download is in progress.
When the download is complete, the following UIM message will appear:
0452 - RTDB reload complete
Recovery
- If this alarm displays while an RTDB download is in progress, no further action is necessary.
- If this alarm displays when an RTDB download is not in progress, capture the log files on both ELAPs (see Saving Logs Using the ELAP GUI) and contact My Oracle Support.
4000000000000800 - Transaction Log Full
The transaction log is full.
Recovery
4000000000001000 - RTDB 100% Full
The RTDB on the ELAP is at capacity. The ELAP RTDB is not updating.
You may be able to free up space by deleting unnecessary data in the database. The ELAP must be upgraded in order to add disk capacity.
Recovery
4000000000002000 - RTDB Resynchronization In Progress
This message indicates that the RTDB resynchronization is in progress.
Recovery
- No further action is necessary.
4000000000004000 - RTDB Reload Is Required
This message indicates that the RTDB reload is required because the transaction logs did not contain enough information to resynchronize the databases (the transaction logs may be too small).
Caution:
If both sides are reporting this error, contact My Oracle Support.
If only one side is reporting this error, use the following procedure.
Recovery
- Log in to the User Interface screen of the ELAP (see Accessing the ELAP Text Interface).
- Refer to LNP Database Synchronization for the correct procedures.
4000000000400000 - LVM Snapshot detected that is too old
LVM alarms are valid for ELAP 8.0 and later.This alarm indicates that an LVM snapshot has been present on the system for longer than 30 minutes. LVM snapshots should not exist for longer than 15 minutes or performance may be degraded as the LVM snapshot overfills with data.
The Logical Volume Manager (LVM) creates read-only snapshots of the database. These LVM snapshots are present when an audit of the LSMS database is active and when the database is being downloaded to EAGLE. An LVM snapshot provides rollback and recovery capability to the active database. All LVM snapshots are removed when no longer needed, or are removed and recreated when in continuous use such as during an LSMS audit which may last several hours.
Recovery
4000000000800000 - LVM Snapshot detected that is too full
This alarm usually occurs when an LVM snapshot has remained in existence too long and has a higher full percentage than expected; however, the alarm may occur also if an unusually large number of updates, distributed evenly across the entire database, have been received.
Recovery
4000000001000000 - LVM Snapshot detected with invalid attributes
An LVM snapshot has been detected with invalid attributes. This alarm may occur if an LVM snapshot cannot be removed completely due to an error in the LVM subsystem. Restarting the ELAP software may clear this condition.
Recovery
4000000002000000 - DRBD Split Brain
This alarm occurs when the ELAP A and B servers have simultaneous outages or if the three heartbeat paths are lost between the two servers. If either condition occurs, neither server can determine which server has the most recent copy of the database. The first system to recover becomes the HA active system. Manual action is required to determine which copy of the shared data is valid and to resynchronize with the other system.
Recovery
4000000010000000 - An instance of Snapmon already running
- prov1snap
- prov2snap
- auditsnap
- backupsnap
Recovery
Minor platform alarms involve disk space, application processes, RAM, and configuration errors.
1000000000000001 – Breaker panel feed unavailable
Alarm Type: TPD
Description: This alarm is generated by the MPS syscheck software package and is not part of the TPD distribution. Refer to MPS-specific documentation for information regarding this alarm.
Severity: Critical
OID: 1.3.6.1.4.1.323.5.3.18.3.1.1.1
Recovery
- See 910-5129-001 Rev. A, PM&C/T5100 Platform Troubleshooting Guide.
5000000000000001 - Server Disk Space Shortage Warning
A file system has exceeded a warning threshold, which means that more than 80% (but less than 90%) of the available disk storage has been used on the file system.
More than 80% (but less than 90%) of the total number of available files have been allocated on the file system.
Recovery
- Run
syscheck(see Running syscheck Through the ELAP GUI) - Examine the
syscheckoutput to determine if the file system/var/TKLC/epap/free/var/TKLC/elap/freeis the one that is low on space. If the file system is low on disk space, continue to 3; otherwise go to 4. - You may be able to free up space on the free partition by deleting unnecessary files, as follows:
5000000000000002 - Server Application Process Error
Recovery
5000000000000004 - Server Hardware Configuration Error
Recovery
- Run
syscheckin verbose mode. - Call My Oracle Support for assistance.
5000000000000008 - Server RAM Shortage Warning
This alarm indicates one of two conditions:
- Less memory than the expected amount is installed.
- The system is swapping pages in and out of physical memory at a fast rate, indicating a possible degradation in system performance.
This alarm may not clear immediately when conditions fall below the alarm threshold. Conditions must be below the alarm threshold consistently for the alarm to clear. The alarm may take up to five minutes to clear after conditions improve.
Recovery
5000000000000020 - Server Swap Space Shortage Warning
This alarm indicates that the swap space available on the server is less than expected. This is usually caused by a process that has allocated a very large amount of memory over time.
5000000000000040 - Server Default Router Not Defined
This alarm indicates that the default network route is either not configured or the current configuration contains an invalid IP address or hostname.
Caution:
When changing the server’s network routing configuration it is important to verify that the modifications will not impact the method of connectivity for the current login session. It is also crucial that this information not be entered incorrectly or set to improper values. Incorrectly modifying the server’s routing configuration may result in total loss of remote network access.
Recovery
5000000000000080 – Server temperature warning
Alarm Type: TPD
Description: This alarm indicates that the internal temperature within the server is outside of the normal operating range. A server Fan Failure may also exist along with the Server Temperature Warning.
Severity: Minor
OID: tpdTemperatureWarningNotify 1.3.6.1.4.1.323.5.3.18.3.1.3.8
Alarm ID: TKSPLATMI85000000000000080
Recovery
5000000000000100 - Server Core File Detected
This alarm indicates that an application process has failed and debug information is available.
Recovery
5000000000000200 - Server NTP Daemon Not Synchronized
This alarm indicates that the NTP daemon (background process) has been unable to locate a server to provide an acceptable time reference for synchronization.
Severity: Minor
Alarm ID: TKSPLATMI10
Recovery
5000000000000400 - Server CMOS Battery Voltage Low
The presence of this alarm indicates that the CMOS battery voltage has been detected to be below the expected value. This alarm is an early warning indicator of CMOS battery end-of-life failure which will cause problems in the event the server is powered off.
Recovery
5000000000000800 - Server Disk Self Test Warning
A non-fatal disk issue (such as a sector cannot be read) exists.
Recovery
5000000000001000 - Device Warning
This alarm indicates that either a snmpget cannot be performed on the configured SNMP OID or the returned value failed the specified comparison operation.
Recovery
- Run
syscheckin Verbose mode. (See Running the System Health Check.) - Call My Oracle Support for assistance.
5000000000002000 - Device Interface Warning
This alarm can be generated by either an SNMP trap or an IP bond error. If syscheck is configured to receive SNMP traps, this alarm indicates that a SNMP trap was received with the set state. If syscheck is configured for IP bond monitoring, this alarm can mean that a slave device is not operating, a primary device is not active, or syscheck is unable to read bonding information from interface configuration files.
Recovery
- Run
5000000000004000 - Server Reboot Watchdog Initiated
This alarm indicates that the server has been rebooted due to a hardware watchdog.
Recovery
5000000000008000 - Server HA Failover Inhibited
This alarm indicates that the server has been inhibited and HA failover is prevented from occurring.
Recovery
5000000000010000 - Server HA Active To Standby Transition
This alarm indicates that the server is in the process of transitioning HA state from Active to Standby.
Recovery
5000000000020000 - Server HA Standby To Active Transition
This alarm indicates that the server is in the process of transitioning HA state from Standby to Active.
Recovery
5000000000040000 - Platform Health Check Failure
This alarm indicates a syscheck configuration error.
Recovery
5000000000080000 - NTP Offset Check Failure
This alarm indicates that time on the server is outside the acceptable range or offset from the NTP server. The alarm message provides the offset value of the server from the NTP server and the offset limit set for the system by the application.
Alarm Type: TPD
Severity: Minor
Alarm ID: TKSPLATMI20
Recovery
5000000000100000 - NTP Stratum Check Failure
This alarm indicates that NTP is syncing to a server, but the stratum level of the NTP server is outside the acceptable limit. The alarm message provides the stratum value of the NTP server and the stratum limit set for the system by the application.
Recovery
5000000020000000 – Server Kernel Dump File Detected
Alarm Type: TPD
Description: This alarm indicates that the kernel has crashed and debug information is available.
Severity: Minor
OID: 1.3.6.1.4.1.323.5.3.18.3.1.3.30
Alarm ID: TKSPLATMI305000000020000000
Recovery
- Run syscheck in Verbose mode (see Running the System Health Check).
5000000040000000 – TPD Upgrade Failed
Alarm Type: TPD
Description: This alarm indicates that a TPD upgrade has failed.
Severity: Minor
OID: tpdServerUpgradeFailDetectedNotify 1.3.6.1.4.1.323.5.3.18.3.1.3.31
Alarm ID: TKSPLATMI315000000040000000
Recovery
5000000080000000– Half Open Socket Warning Limit
Alarm Type: TPD
Severity: Minor
OID: tpdHalfOpenSocketWarningNotify1.3.6.1.4.1.323.5.3.18.3.1.3.32
Alarm ID: TKSPLATMI325000000080000s000
Recovery
- Run syscheck in verbose mode (see Running the System Health Check ).
- Run
syscheck(see Running syscheck Using the syscheck Login) - Contact My Oracle Support and provide the system health check output.
5000000000200000 - SAS Presence Sensor Missing
Recovery
- Call My Oracle Support for assistance with a replacement server.
5000000000400000 - SAS Drive Missing
This alarm indicates that the number of drives configured for this server is not being detected.
Recovery
- Call My Oracle Support to determine if the alarm is caused by a failed drive or failed configuration.
5000000000800000 - DRBD failover busy
This alarm indicates that a DRBD sync is in progress from the peer server to the local server. The local server is not ready to bethe primary DRBD node because its data is not current.
Recovery
- Wait for approximately 20 minutes, then check if the DRBD sync has completed. A DRBD sync should take no more than 15 minutes to complete.
- If the alarm persists longer than this time interval, call My Oracle Support for assistance.
5000000001000000 - HP disk resync
This alarm indicates that the HP disk subsystem is currently resyncing after a failed or replaced drive, or after another change in the configuration of the HP disk subsystem. The output of the message will include the disk that is resyncing and the percentage complete. This alarm eventually clears after the resync of the disk is completed. The time to clear is dependant on the size of the disk and the amount of activity on the system..
Recovery
- Run
syscheckin Verbose mode. - If the percent recovering is not updating, wait at least 5
minutes between subsequent runs of
syscheck, then call My Oracle Support with thesyscheckoutput.
Minor application alarms involve RTDB capacity and software errors.
4000000000020000 - Automatic RTDB Backup is not configured
This is an indication that the Automatic RTDB Backup is not configured on the system, i.e., the Backup Type is "None."
Recovery
- Configure the Automatic RTDB backup with backup type other than None. Refer to Automatic RTDB Backup for details on how to configure the Automatic RTDB Backup.
6000000000000200 - RTDB Backup Failed
This alarm indicates that the system was unable to complete an RTDB backup.
Recovery
6000000000000400 - Automatic RTDB Backup Failed
This alarm indicates that the system was unable to complete an automatic RTDB backup.
Recovery
6000000000000800 - Automatic Backup cron entry modified
This alarm indicates that the cron entry for automatic backups has been modified. No further action is required.
6000000000002000 - Configurable Quantity Threshold Exceeded
This alarm indicates that the RTDB file system has reached the user-configured threshold.
Recovery
- If the user-configurable threshold is set to less than 90%, then the user may increase the threshold to a higher value.
- Log in to the User Interface of the ELAP GUI. See Accessing the ELAP GUI Interface.
- Select to change the threshold value (1-99). See ELAP Administration and LNP Feature Activation for additional information.
- If the user-configurable threshold is set to 90% or higher, call My Oracle Support for assistance.
6000000000020000 - Automatic RTDB Backup is not configured
Recovery
