Required Elements Before Entering A State
You can define additional elements that are required before a business entity can enter a given state. For example, let's assume that a Cancel Reason must be defined before an object can enter the Canceled state. You do this by indicating that element as a Required Element state-specific option on the appropriate state on the business object.
