Defining M&V Calculation Groups
You use the M&V Calculation Group portal to display and maintain Measurement and Verification calculation groups.
Refer to Understanding M&V Calculation Groups for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select M&V Calculation Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • M&V Calculation Group: This zone displays basic information about M&V calculation group.
  • M&V Calculation Rules List: This zone lists the M&V calculation rules belonging to the group.
