Defining M&V Calculation Rules
You use the M&V Calculation Rule portal to display and maintain Measurement and Verification calculation rules.
Refer to Understanding M&V Calculation Rules and Understanding M&V Calculation Groups for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select M&V Calculation Rule. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • M&V Settlement Calculation Rule: This zone displays the M&V calculation rule, including parameters used when executing the rule.
  • Eligibility Criteria List: This zone lists eligibility criteria for the current calculation rule. Eligibility criteria are configured criteria used to determine whether to execute a specific calculation rule.
The following is a list of the calculation rules provided as part of base product that are used with M&V calculations. For more information on how each rule executes and can be configured, follow the link provided on the rule.
Program Settlement Calculation Rule Name Purpose
Vector and Service Quantity Math (D2-Math) This rule is designed to facilitate configuration of complex vector calculations. It is based on a series of underlying services with vectors configured as input to the calculations.
