Maintaining Program and Customer Settlement Transactions
The Program Settlement portal is used to display and maintain program and customer settlement transactions, , including program incentives and fees.
Refer to About Program Settlement Transactions, About Program Incentives and Fees, and About Customer Settlement Transactions for more information.
You can access the portal from Menu, select Digital Asset Management, then select Program Settlement. You are brought to a query portal with options for searching for a specific record. Once a settlement transaction has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Program Settlement: This zone displays the selected settlement transaction.
  • Program Settlements: This zone displays a list the program settlements totalized in the selected customer settlement transaction.
