Maintaining Program Control Scores
The Program Control Score portal is used to display and maintain program control scores.
Refer to About Program Control Scores for more information.
You can access the portal from Menu, select Digital Asset Management, then select Program Control Score. You are brought to a query portal with options for searching for a specific record. Once a program control score has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Program Control Score: This zone displays the selected program control score.
