Tailoring Web Files
Base product UI files are located in the directory $SPLEBASE/splapp/applications/root
. Implementers may develop their own UI files under the directory $SPLEBASE/splapp/applications/root/cm
. No specific naming conventions are enforced under this directory.
The root directory may be deployed in war file format for runtime environment (SPLApp.war
). Use provided utilities to incorporate your cm directory into the SPLApp.war
file.
