Tailoring XML Schema
Note: This implementation option is applicable for Oracle Enterprise Taxation Management application only.
Implementers may generate their own XML schemas and store them in the directory $SPLEBASE/ splapp/xmlMetaInfo
. The implementation schemas must use the naming convention CML*.xml
