Oracle Utilities Market Settlements Management Server Administration Guide
Updates to This Documentation
Other Documentation
Reference Papers
Notes
Architecture
Roles and Features
Browser Client
Web Application Server
Business Application Server
Database Server
Batch Server
Concepts
Environment
Environment Identifier
Server Roles
Administration User Id and Group
Native Support
Directory Structure
Software Directory Structure
Software (splapp) Directory
Tools Directory
Directory Permissions
Output Structure
Environment Variables
Common Application Logs
Batch Concepts
Batch Clustering Concepts
Batch Controls
Standard Parameters
Additional Key Parameters
Batch Run Tree
Timed Jobs
Level of Service
Explanation of Commit Interval
Explanation of Thread Limit and Thread Number
Explanation of Restart and Rerun
Submission Methods
Operations
Command Line Utilities
bedit - Batch Edit
buildJavadocsIndex.sh - Builds Appviewer java docs
configureEnv – Set up Environment Settings
createDBStandalone.sh - Creates Database Patches
extractCMSourceUNIX.sh - Migrate Code Across Upgrades
genappvieweritems – generate AppViewer
initialSetup – Maintain Configuration Settings
installSFGroup.sh - Install Software Patches
invokeDBUpdatePatch.sh - Regenerates passwords in Installation Options
iwsdeploy - Inbound Web Services Deployment
jmxbatchclient.sh – JMX batch command line
ouafDatabasePatch.sh - Install Database Patches
PatchDeployUtility.sh - Create and Deploy Patch Rollups
showjavaproc.sh - Show java processes
splenviron – Set Environment Variables
starttpw.sh - Start Threadpoolworker
submitjob.sh - Submit Batch Threads
threadpoolworker.sh - Manage Threadpools
Starting and Stopping Using Consoles
Monitoring
Monitoring Regimes
Monitoring Client Machines
Monitoring the Desktop
Client Debug Facility
Monitoring Web/Business Application Server
JMX Based Monitoring
Web Application Server JMX Reference
Business Application Server JMX Reference
Batch JMX Reference
JMX Security
Extending JMX Security
Execution Dump Format
Service Lists
Resetting Statistics
Database Connection Monitoring
Probe Transaction
Configuration
Configuration Files
cistab - Global Configuration Files
coherence-cache-config.xml - Oracle Coherence Configuration (BATCH)
e0Batch.properties - General Batch Properties
ejb-jar.xml - Enterprise Java Server Beans Configuration
ENVIRON.INI - Environment Configuration File
hibernate.properties - Database Connectivity Settings
log4j2.properties – Product Logging Configuration
Server Jar File (ouaf_jar_versions.txt)
spl.properties – Product Behaviour Settings
submitbatch.properties - Submitter Configuration (BATCH)
tangosol-coherence-override.xml - Coherence Overrides (BATCH)
threadpoolworker.properties - Threadpool Configuration (BATCH)
web.xml – JEE Deployment Descriptor
weblogic.xml – Oracle WebLogic Extensions
weblogic-ejb-jar.xml - WebLogic Extensions for Enterprise Java Server Beans
webservices.xml.resource - Web Services Configuration
Web Browser Configuration
Web Application Server Configuration
Web Application Server Concepts
Web Applications
Web Application Server Configuration Files
Quick Reference Guide for Web Application Server Configuration
User Interface Backward Compatibility Settings
Web Application Server Deployment Process
Business Application Server Configuration
Business Application Server Concepts
Business Application Server Configuration Files
Business Application Server Configuration Process
Quick Reference Guide for Business Application Server Configuration
Business Application Server Deployment Process
Inbound Web Services Configuration
Enabling Inbound Web Services
Inbound Web Services Configuration Files
Inbound Web Services Concepts
Inbound Web Services Configuration Process
Inbound Web Services Deployment Process
Quick Reference Guide for Inbound Web Services Configuration
Inbound Web Services Deployment Utilities
Batch Server Configuration
Batch Configuration Files
General Configuration Process
Configuring Batch Using Bedit
Batch Configuration Guidelines
Oracle Cloud Support
Support for host allow listing
Support for URI specification using Substitution Variables
Defining File Alias Using Extendable Lookup
Support for Oracle Cloud Storage Access
Consolidated logging
Diagnostics Support (WLDF)
ECID Support
Global Cache Flush Support
Java Flight Recorder Support
Work Manager Support
Trust Store Support
Miscellaneous Operations and Configuration
Enabling Email Logging from Log4j2
Overriding the Default Oracle Database Connection Information
Centralized Properties Customization
Cache Management
Server Cache
Client Cache
Oracle WebLogic: Expanded or Archive Format
Implementing Custom Templates
Additional Templates
Sending Emails at the Conclusion of Batch Processes
Oracle WebLogic Configuration Support
Using Configuration Files Outside the WAR/EAR File
Oracle RAC Support
Adding a Custom Privacy Policy Screen
User Exit Include Files
Properties File User Exits
Custom JMS Configuration
Online Transaction Timeouts
Setting the Date for Testing Purposes
Secure Transactions
Native Oracle WebLogic Support
Manual Re-Deployment Process
Oracle WebLogic Console Operations
Starting and Stopping from Console
Monitoring Web Applications Using the Console
Specifying Custom Log File Names
Turning off L2 Cache
JDBC Support
Cancelling Batch Processes Using JMX
Operations from Oracle Enterprise Manager
Discovering Oracle Utilities Targets
Discovering Oracle WebLogic Targets
Monitoring Using Oracle Enterprise Manager
Oracle Scheduler Integration
Background Materials
Oracle Scheduler Interface Overview
Oracle Scheduler Configuration
Oracle Scheduler Execution
Oracle Scheduler Interface (OUAF_BATCH)
Submit_Job - Submit a Job or Thread
Restart_Thread - Restart a Failed Thread/Job
Cancel_Job - Cancel a Running Job
Set_Option - Set a Global or Job Option
Unset_Option - Reset a Global or Job Option
Raise_Thread_Error - Raise an Error
Setting Preferences
Order of Preference
Using soft_parm_map
Using soft_parm_list
Oracle Scheduler – REST APIs
F1-DBMSProgram Service
F1-DBMSChain Service
F1- DBMSSchedule Service
F1-DBMSJob Service
F1-DBMSJob Service
F1-DBMSSubmitJob Service
F1-DBMSGetJobDetails Service
F1-DBMSGetJobs Service
F1-DBMSCancelJob Service
F1-DBMSRestartThread Service
F1-DBMSRestartChain Service
Building a Schedule
Recommended Tools
Defining Programs
Defining Job Classes
Defining Schedules
Defining Remote Destinations and Credentials
Defining Jobs
Defining Chains
Other Scheduler Objects
Executing Jobs
Monitoring Oracle Scheduler
Job States
Dictionary Views
Scheduler Notifications
Cancellation
Exporting Schedules Across Environments
Parameters
Conventions
ENVIRON.INI
ALLOW_SELFSIGNED_SSL – Enable Self-Signed SSL
ANT_ADDITIONAL_OPT - Additional Options for ANT
ANT_HOME - Location of ANT
ANT_OPT_MAX - ANT Maximum Heap Size
ANT_OPT_MIN - ANT Minimum Heap Size
appViewer - Name of appViewer WAR File
BATCHDAEMON - Whether Online Batch Daemon is Enabled
BATCHEDIT_ENABLED - Whether Batch Edit Facility is Enabled
BATCHENABLED - Whether Online Batch Server is Enabled
BATCHTHREADS - Number of Online Batch Server Threads
BATCH_DBPASS - Batch User Password
BATCH_DBUSER - Batch User
BATCH_MEMORY_ADDITIONAL_OPT - Threadpool Worker JVM Additional Options
BATCH_MEMORY_OPT_MAX - Threadpool Worker Java Maximum Heap Size
BATCH_MEMORY_OPT_MIN - Threadpool Worker Java Minimum Heap Size
BATCH_MODE - Default Mode of Batch
BATCH_ONLINE_LOG_DIR - Online Batch Submission Log Directory
BATCH_RMI_PORT - RMI Port for Batch
BSN_APP - Business Server Application Name
BSN_JMX_RMI_PORT_PERFORMANCE - JMX Port for Business Application Server
BSN_JMX_SYSPASS - Password for BAS JMX Monitoring
BSN_JMX_SYSUSER - Default User for BSN JMX Monitoring
BSN_WLHOST - Business App Server Host
CALC_WLS_COMMON_JAR_DIR – Weblogic’s Jersey Jars Directory
CALC_WLS_SERVER_JAR_DIR– Weblogic Server Lib Jars Directory
CHAR_BASED_DB – Specifies if the DB Is Char-Based
CLOUD_CUSTOM_WHITE_LIST_PATH - Custom URL Allow Lists for Cloud
CLOUD_LOCATION_F1_BASE_IWS_URL – URI for Variable F1_BASE_IWS_URI
CLOUD_LOCATION_F1_BASE_REST_URL – URI for Variable F1_BASE_REST_URL
CLOUD_LOCATION_F1_BASE_WEB_URI – URI for Variable F1_BASE_WEB_URI
CLOUD_LOCATION_F1_MIGR_ASSISTANT_FILES – Location of CMA Files for Migrations
CLOUD_LOCATION_F1_OAUTH2_URI – URI for OAUTH2
CLOUD_RESTRICTIONS_URLS_ENABLE - Enable or Disable URL Restrictions
CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION - Enable or Disable URL Restrictions
CLOUD_WHITE_LIST_PATH - URL Allow Lists for Cloud
CMPDB - Database Type
CM_INSTALL_SAMPLE - Whether samples are installed
COHERENCE_CLUSTER_ADDRESS - Multicast address for Batch Cluster
COHERENCE_CLUSTER_MODE - Batch Cluster Mode
COHERENCE_CLUSTER_NAME - Batch Cluster Name
COHERENCE_CLUSTER_PORT - Batch Cluster Port Number
CONSOLIDATED_LOG_FILE_PATH- Directory for Consolidated Log File
CORS_HOST – Source for Cross Origin Resource Sharing
CORS_PORT - Source Port for Cross Origin Resource Sharing
CORS_SCHEME - Scheme to be used for Cross Origin Resource Sharing
CSRF_PROTECTION – Cross-Site Request Forgery Protection
CUSTOM_SQL_SECURITY – Enable Custom SQL Security
DBCONNECTION - JDBC Connection String
DBDRIVER - Database Driver
DBNAME - Database Name
DBPASS - Online Database User Password
DBPASS_GEOCODE_WLS - GEOCODE Database Password
DBPASS_MDS - MDS Database Password
DBPASS_ORASDPM - DPM Database Password
DBPASS_OSB - OSB Database Password
DBPASS_SOAINFRA - SOA Database Password
DBPORT - Database Listener Port
DBSERVER - Database Server
DBURL_GEOCODE - GEOCODE JDBC URL
DBURL_OSB - OSB JDBC URL
DBURL_SOA - SOA Suite JDBC URL
DBUSER - Online Database User
DBUSER_GEOCODE - GEOCODE Database User
DBUSER_MDS - SOA MDS Database User
DBUSER_ORASDPM - DPM Database User
DBUSER_OSB - OSB Database User
DBUSER_SOAINFRA - SOA Database User
DB_OVERRIDE_CONNECTION - Custom JDBC URL
DESC - Environment Description
DIALECT - Hibernate Dialect
DIRSEP - Directory Separator
DOC1BILLSCRIPT - Name of External Print Script
DOC1SCRIPT - Name of Generic Print Script
ENABLE_CORS – Enable Cross Origin Resource Sharing
ENABLE_JMS_GLOBAL_FLUSH – Enable Flushing of JMS
ENCODING - Whether Encryption Is Enabled
ENVIRONMENT_ID - Environment Identifier
FORCE_HTTP – Enforce HTTP Protocol
FW_VERSION - Oracle Utilities Application Framework Version
FW_VERSION_NUM - Oracle Utilities Application Framework Version Identifier
GIS - GIS Support
GIS_URL - GIS Service URL
GIS_WLSYSPASS - GIS WebLogic System Password
GIS_WLSYSUSER - GIS WebLogic System User Id
GLOBAL_JVMARGS - Additional JVM Arguments
HEADEND_CD_CB - Headend System URI for SOA Configuration Plan (CD_CB)
HEADEND_MR_CB - Headend System URI for SOA Configuration Plan (MR_CB)
HIBERNATE_JAR_DIR - Location of Hibernate JAR Files
HIGHVALUE - Language Specific Highvalues
HSTS_MAX_AGE – Maximum Age of Strict Transport Security
HSTS_PRELOAD – Strict Transport Security Preload
HSTS_SUBDOMAINS – Subdomains Included in Strict Transport Security
IWS_JDBC_NAME - JNDI Name for the IWS Connection Pools
IWSWAR - Name of Inbound Web Services WAR
JAVAENCODING - Java Language Encoding
JAVA_HOME - Location of Java SDK
JAVA_VENDOR - Java Vendor
JAVA_VERSION - JVM Version String
JAVA_VERSION_MAIN - Abberviated JVM Version
JDBC_NAME - JNDI Name for the Online JDBC Data Source
JDBC_TIMEOUT – JDBC Read Timeout
JNDI_GEOCODE - Geocode Data Source JNDI
JNDI_OSB - OSB Data Source JNDI
KS_IMPORT_KEYSTORE_FOLDER - Keystore Import Folder
LD_LIBRARY_PATH - Library Path for Windows/Linux/Solaris
MODULES - Names of Modules Installed (Deprecated)
NLS_LANG - NLS Language Setting
ONLINE_DISPLAY_HOME - Location of Print Rendering Software
ONS_JAR_DIR - Location of Oracle Notification Service Libraries
ONSCONFIG - ONS Configuration
OPSYS - Operating System
ORACLE_CLIENT_HOME - Oracle Client Home
OSB_HOME - Oracle Service Bus Home
OSB_HOST - Oracle Service Bus Host Name
OSB_LOG_DIR - Default Location For Oracle Service Bus Logs
OSB_PASS_WLS - Password for Oracle Service Bus User
OSB_PORT_NUMBER - Oracle Service Bus Port Number
OSB_USER - User Name for Oracle Service Bus
OUAF_DBMS_SCHEDULER_USER – DB User of DBMS Scheduler
OWSM_PROTECTION_FOR_REST_SERVICES – Enable Oracle Web Services Manager protection for REST
PERLHOME - Location of PERL
SERVER_ROLES - Which Server Roles Are Enabled
SERVER_ROLE_BATCH - Whether the Batch Server Is Enabled in This Installation
SERVER_ROLE_INTEGRATION - Whether the IWS Server Is Enabled in This Installation
SERVER_ROLE_ONLINE - Whether the Online Server Is Enabled in This Installation
SOA_HOME - Location of Oracle SOA Suite
SOA_HOST - Hostname for Oracle SOA Suite
SOA_PORT_NUMBER - Port Number for Oracle SOA Suite
SPLADMIN - Administration Userid
SPLADMINGROUP - Administration Group
SPLApp - Name of Online WAR File
SPLDIR - Home Directory of Product
SPLDIROUT - Location of Product Output
SPLENVIRON - Environment Identifier
SPLOUTPUT - Directory for Product Output
SPLSERVICEAPP - Name of Business Application Server Application
SPLWEBAPP - Name of Web Application Server Application
STRICT_TRANSPORT_SECURITY – Enable Strict Transport Security
STRIP_HTML_COMMENTS - Strip Out Comments In Code
TEMPSTORAGE_SPLITFILESIZE - Split File Size in MB
TOP_VERSION - Product Version
TOP_VERSION_NUM - High level Product Version
WEB_ADMIN_SERVER – Name of the Web Admin Server
WEB_APP - Name of WebSphere Server Application
WEB_APPVIEWER_FORM_LOGIN_ERROR_PAGE - AppViewer Form Login Error Page
WEB_APPVIEWER_FORM_LOGIN_PAGE - AppViewer Form Login Page
WEB_APPVIEWER_PRINCIPAL_NAME - Application Viewer Principal Name
WEB_APPVIEWER_ROLE_NAME - Application Viewer Security Role
WEB_CONTEXT_ROOT - Web Context Root
WEB_DEPLOY_APPVIEWER - Deploy AppViewer
WEB_ENABLE_HEALTHCHECK - Enable System Healthcheck
WEB_FORM_LOGIN_ERROR_PAGE - Default Form Login Error Page
WEB_FORM_LOGIN_PAGE - Default Form Login Page
WEB_HELP_FORM_LOGIN_ERROR_PAGE - Help Form Login Error Page
WEB_HELP_FORM_LOGIN_PAGE - Help Form Login Page
WEB_ISAPPVIEWER - Enable AppViewer
WEB_ISDEVELOPMENT - Development Environment
WEB_IWS_MDB_RUNAS_USER - Default User for MDB to Run as within Product
WEB_IWS_SUPER_USERS - Users to Run as in IWS
WEB_JMX_RMI_PORT_PERFORMANCE - JMX Port for Web Application Server Monitoring
WEB_L2_CACHE_MODE - Turn off L2 Cache for Online Submission
WEB_MAXAGE - Text Cache
WEB_MAXAGEI - Image Cache
WEB_PRELOADALL - Preload All Pages on Startup
WEB_PRINCIPAL_NAME - Default JEE Authorization Principal
WEB_ROLE_NAME - Default JEE Authorization Role
WEB_SERVER_HOME - Location of Web Application Server
WEB_SERVER_VERSION - Web Server Version
WEB_SERVER_VERSION_MAIN
WEB_WLAUTHMETHOD - Authentication Method
WEB_WLHOST - Web Server Host
WEB_WLPAGECHECKSECONDS - Interval for Recompilation of JSP
WEB_WLPORT - Web Server HTTP Port
WEB_WLSSLPORT - Oracle WebLogic SSL HTTP Port
WEB_WLSYSPASS - Oracle WebLogic JNDI System Password
WEB_WLSYSUSER - Oracle WebLogic JNDI System Userid
WEB_WLS_SVRNAME - Oracle WebLogic Server Name
WLS_ADMIN_PORT - Admin Console Port Number
WLS_CLUSTER_NAME - Name of Cluster for Product
WLS_DIAGNOSTIC_CONTEXT_ENABLED - ECID Support
WLS_DOMAIN_HOME - Oracle WebLogic Domain Home
WLTHININT3CLIENT_JAR_DIR - Location of Thin WebLogic T3 Client
WL_HOME - Oracle WebLogic Home
XAI_DBPASS - Password for Database User for IWS
XAI_DBUSER - Database User Used for IWS
XQUERIES_TO_CACHE - Size of XQuery Cache
XQUERY_CACHE_FLUSH_TIMEOUT - Cache Life for XQueries
Web.xml
Filter Mappings - JEE Filters
disableCompression - Disable Compression
maxAgeI - Max Age for Images
maxAge - Max Age for pages
auth-method - Authorization Method
fieldValuesAge - Server Cache Lifetime
disableUIPageCompression - Disable UI Compression
spl.properties
calendar.japanese.eras - Japanese Era Definition
com.oracle.ouaf.customer.whitelist.file – Customer’s URL Allow List File
com.oracle.ouaf.consolidatedLog.fileName – Consolidate Log File
com.oracle.ouaf.dbms.scheduler.schema – DBMS Scheduler Object’s Schema
com.oracle.ouaf.file.tempstorage.dir – Location for Temporary File
com.oracle.ouaf.file.tempstorage.splitfilesize – Split File Size in MB
com.oracle.ouaf.migrationAssistant.exportDirectory – Directory for Exported CMA File
com.oracle.ouaf.migrationAssistant.importDirectory – Directory for CMA File for Import
com.oracle.ouaf.migrationAssistant.fileExtension – Extension of CMA File
com.oracle.ouaf.proxy.password– Proxy Credentials for Senders if JVM is Configured to Use Proxy
com.oracle.ouaf.proxy.user – Proxy Credentials for Senders if JVM Is Configured to Use Proxy
com.oracle.ouaf.system.database.disableTagging - Disables Database Tagging
com.oracle.ouaf.ui.disableRequiredFieldIndicators – Disable Required Field Indicators on UI Map
com.oracle.ouaf.uriSubstitutionVariables.file – URI Predefined Variables List File
com.oracle.ouaf.uriValidation.enable – Enable Restriction of URLs
com.oracle.ouaf.web.disableSecureCookie - Web Pages User Experience Style
com.oracle.ouaf.web.userInterfaceStyle - Web Pages User Experience Style
com.oracle.ouaf.web.oracleGuidedeLearningId - Oracle Guided Learning Identifier
com.oracle.ouaf.whitelist.file – Oracle URL Allow List Filename and Location
com.oracle.XPath.LRUSize - XPath Cache
com.oracle.XPath.flushTimeout - XPath Flush
com.splwg.batch.cluster.jvmName - Online Batch JVM Name
com.splwg.batch.scheduler.daemon - Online Submission Daemon
com.splwg.grid.executionMode - Online Execution Mode
com.splwg.grid.online.enabled - Online Batch Server
com.splwg.grid.distThreadPool.threads.DEFAULT - Online Submission Threadpool
com.splwg.schema.newValidations.F1 - Set Behavior of Validations
jmx.remote.x.access.file - JMX Access Control
jmx.remote.x.password.file - JMX Password Control
oracle.ouaf.jmx.remote.startPort - JMX Override Port
ouaf.accessiblity.features - Enable Accessibility Features
ouaf.attachment.disableSpecialCharCheckOnFileName - Disable Special Characters on File Name
ouaf.batch.onlineLogDir - Online Line Batch Log Directory
ouaf.batch.onlineLogDir.retain – Retain Online Line Batch Log Files
ouaf.database.session.setInstallationTimeZone - Set Time Zone for Sessions
ouaf.flush.jms.disabled - Global Flush Supported
ouaf.flush.jms.connection - Connection Factory for Global Flush
ouaf.flush.jms.requestTopic - Global Flush Request Topic
ouaf.flush.jms.responseTopic - Global Flush Response Topic
ouaf.runtime.compatibility.enablePrecisionScaleOnMoney - Money Processing
ouaf.jmx.com.oracle.ouaf.ws.mbeans.WSFlushBean - WS Cache Flush
ouaf.jmx.com.splwg.base.support.management.mbean.JVMInfo - JVM Information
ouaf.jmx.com.splwg.base.web.mbeans.FlushBean - Manage Cache
ouaf.list.buffer.limit - List Iteration Limit
ouaf.messaging.transformerfactory - Transformer
ouaf.shortcut.ignore.altKeys - Disable Hot Keys
ouaf.timeout.business_object.default - Set Default Business Object Timeout
ouaf.timeout.business_object.<bocode> - Set Specific Business Object Timeout
ouaf.timeout.business_service.default - Set Default Business Service Timeout
ouaf.timeout.business_service.<bscode> - Set Specific Business Service Timeout
ouaf.timeout.query.default - Set Default Query Timeout
ouaf.timeout.query.<zonecode> - Set Specific Query Timeout
ouaf.timeout.script.default - Set Default Script Timeout
ouaf.timeout.script.<scriptname> - Set Specific Script Timeout
ouaf.timeout.service.default - Set Default Service Timeout
ouaf.timeout.service.<service> - Set Specific Service Timeout
ouaf.web.appViewer.coreAppURL - AppViewer Callback URL
ouaf.web.disablePreload - Disable Screen Preload
ouaf.web.help.coreAppURL - Help Callback URL
ouaf.web.helpRootURL - Help URL
ouaf.web.JspHeader.maxAge - JSP Age
ouaf.web.preloadAllPages - Preload Scope
ouaf.web.useOHW - Use Oracle Help for Web Engine
ouaf.weblogic.enableDiagnostics - Enable ECID Tracking
ouaf.webservices.security.defaultPolicy – IWS Customized Security Policy
ouaf.ws.defaultUser - Default User for Web Services
ouaf.ws.deploy.appxml.file - Application XML File for Inbound Web Services
ouaf.ws.deploy.ear - EAR File Name for Inbound Web Services
ouaf.ws.deploy.contextpath - Context Path for Inbound Web Services
ouaf.ws.pageService.annotations - Security Annotation for XAI Legacy services
ouaf.ws.superusers - Effective Web Services Users
ouaf.ws.tools.artifact.generated.buildfile - Build File
ouaf.ws.tools.artifact.generated.sourcedir - Location of generated source
ouaf.ws.tools.artifact.resource.dir - Location of Resources
ouaf.ws.tools.artifact.schema.dir - Location of Schemas
ouaf.ws.tools.artifact.xsl.dir - Web Service XSL Location
ouaf.ws.tracing - Inbound Web Services Tracing
ouaf.ws.xslDirOverride - Override XSL Location
spl.csv.delimiter.useFromDisplayProfile - List CSV Delimiter
spl.ejbContainer.contextFactory - Context Factory for Business Application Server
spl.ejbContainer.password - Password for Business Application Server
spl.ejbContainer.url - Business Application Server URL
spl.ejbContainer.user - Business Application Server User
spl.geocodeDatasource.contextFactory - GIS Context Factory
spl.geocodeDatasource.password - GIS Connection Password
spl.geocodeDatasource.url - GIS Data Source
spl.geocodeDatasource.user - GIS Connection User
spl.runtime.compatibility.uiMapDisableInputValue - Map Defaults
spl.runtime.compatibility.uiMapDropdownSelectFirstValue - Drop-down defaults
spl.runtime.compatibility.uiMapDisableTitle - Screen Title Defaults
spl.runtime.compatibility.uiMapDisableGenerateUniqueHtmlIDs - Map Ids
spl.runtime.customSQLSecurity – Enable SQL Allow List
spl.runtime.disableCSRFProtection - Disable Security Tokens
spl.runtime.environ.init.dir - Location of Configuration Files
spl.runtime.environ.isWebExpanded - Expanded Mode
spl.runtime.environ.SPLEBASE - Location of Software
spl.runtime.initiatize.waittime - Start Time Delay
spl.runtime.environ.SPLOUTPUT - Location of Output
spl.runtime.management.batch.cluster.url - Batch Cluster URL
spl.runtime.management.connector.url.default - JMX URL
spl.runtime.management.rmi.port - JMX Port
spl.runtime.options.isFCFEnabled - RAC FCF Enabled
spl.runtime.options.onsserver=nodes - ONS Configuration
spl.runtime.options.allowSystemDateOverride - Set Testing Date
spl.runtime.options.createSimpleWebAppContextEnable - Web Cache Loading
spl.runtime.options.isDevelopmentMode - Development Mode
spl.runtime.oracle.statementCacheSize - Java SQL Cache Size
spl.runtime.performSignedNumberValidation.<product> - Number Validation
spl.runtime.service.extraInstallationServices - Installation Service
spl.runtime.sql.highValue - SQL High Value
spl.runtime.utf8Database - UTF8 Support
spl.runtime.warning.dialog.before.download - Enable Warning Message Before Data Download
spl.serviceBean.jndi.name - JNDI Name for Business Application Server
spl.tools.loaded.applications - Loaded Product
ouaf.propertyfile.usage – Properties Usage
hibernate.cache.use_second_level_cache - Use Cache
hibernate.connection.datasource - JNDI Data Source
hibernate.connection.driver_class - Connection Driver Class
hibernate.connection.password - Database User Password
hibernate.connection.provider_class - Connection Provider
hibernate.connection.release_mode - Connection Release
hibernate.connection.url - JDBC URL
hibernate.connection.username - Database User
hibernate.dialect - Dialect Used
hibernate.jdbc.batch_size - JDBC2 Update Support
hibernate.jdbc.fetch_size - Solution Set Size
hibernate.max_fetch_depth - Join Fetch Depth
hibernate.query.factory_class - HQL Parser
hibernate.query.substitutions - Literal Mappings
hibernate.show_sql - Debug Mode
hibernate.transaction.factory_class - Transaction Class
hibernate.ucp.connection_wait_timeout - UCP Connection Timeout
hibernate.ucp.inactive_connection_timeout - Connection Inactivity Timeout
hibernate.ucp.jmx_enabled - Enable UCP JMX
hibernate.ucp.max_size - Maximum Pool Size
hibernate.ucp.max_statements - SQL Buffer Size
hibernate.ucp.min_size - Minimum Pool Size
com.ouaf.batch.jvmoptions - JVM Options
com.splwg.grid.executionMode - Mode of Execution
com.splwg.batch.submitter - THIN Submitter
com.splwg.batch.submitter.batchCd - Batch Code
com.splwg.batch.submitter.distThreadPool - Threadpool
com.splwg.batch.submitter.languageCd - Language Code
com.splwg.batch.submitter.maximumCommitRecords - Commit Interval
com.splwg.batch.submitter.promptForValues - Prompt for Values
com.splwg.batch.submitter.processDate - Business Date
com.splwg.batch.submitter.rerunNumber - Re Run Number
com.splwg.batch.submitter.softParameter - Job Parameters
com.splwg.batch.submitter.threadCount - Thread Limit
com.splwg.batch.submitter.threadNumber - Thread Number
com.splwg.batch.submitter.traceProgramEnd - Trace Program End
com.splwg.batch.submitter.traceProgramStart - Trace Program Start
com.splwg.batch.submitter.traceSQL - Trace SQL Statements
com.splwg.batch.submitter.traceStandardOut - Trace Output Statements
com.splwg.batch.submitter.userId - Security User
spl.runtime.batch.L2CacheMode - L2 Cache Control
tangosol.coherence.distributed.localstorage - Cache Mode
tangosol.coherence.role - Submitter Role
com.oracle.ouaf.batch.scriptDir - Base Scripts Directory for Infrastructure Job
com.ouaf.batch.disableAutoFlush – Auto Flush Batch L2 Cache
com.ouaf.batch.flushIntervalInSeconds – Batch L2 Cache Auto Flush Interval
com.ouaf.batch.jvmoptions - Threadpool JVM Options
com.splwg.grid.executionMode - Threadpool Mode of Execution
com.splwg.grid.distThreadPool.threads - Threadpool Thread Limit
com.splwg.batch.scheduler.daemon - Scheduler Daemon
oracle.ouaf.jmx.remote.maxPortsToTry - Ports to Attempt to Connect to
oracle.ouaf.jmx.remote.startPort - Override Batch JMX Port
spl.runtime.batch.disableDeferredKeyInserts - Deferred Key Inserts
spl.runtime.batch.L2CacheMode - Threadpoolworker L2 Cache Control
spl.runtime.management.connector.url.default - Batch JMX URL
spl.runtime.management.rmi.port - Batch JMX Port
tangosol.coherence.distributed.localstorage - DistributedCache Storage
tangosol.coherence.distributed.threads - Internal Cache Threads
tangosol.coherence.invocation.threads - Internal Invocation Threads
tangosol.coherence.localhost - Unicast Host Address
tangosol.coherence.localport - Unicast Port
tangosol.coherence.localport.adjust - Unicast Port Adjustment
tangosol.coherence.role - Threadpoolworker Role
coherence-cache.config.xml
Oracle Utilities Market Settlements Management 2.5.0.0.0 Server Administration Guide
