The Event Details Options tab allows an administrator to configure the contents of each of the option menus that reside Event Details windows. (See “Understanding Event Details” for more information.)
The Event Details Options pane allows you to add, edit, remove, and reorder the contents of each of the option menus that reside on the Event Details windows (see “Understanding Event Details” for details).
The Event Details Options pane displays the following fields and buttons:
• The Event Type allows you specify which event type configuration you want to modify the options of (for example, Outage, Non Outage, Planned Event, Switching Event).
• The Event Details Option Menus selection menu contains a list of the option menus that exist for the selected Event Type.
• The Options for Currently Selected Menu table populates with the currently configured options for the selected option menu and event types.
• The Add button allows you to add a new option or submenu to the selected option menu for the selected event type.
• The Remove button allows you to remove the selected option.
• The Edit button allows you to edit the selected option.
• The Refresh button refreshes the table with the current contents of the database.
• The Export Configuration... button generates SQL statements for the current state of the configuration associated with the Event Details Options tab. These SQL statements may then be saved to a file and/or printed.
