Asset Details Mapping
The product can be configured to support various mapping approaches between GIS features and assets. The following are high level guidelines to consider when designing such mapping:
Analyze your GIS feature classes
Determine which feature classes should be synchronized.
Determine which GIS fields should be synchronized in each direction.
Determine if value mapping is needed for some GIS values.
Extend the base asset location business object if custom GIS location details need to be supported.
Use asset attributes when possible, to store GIS asset related details
Define corresponding non-tracked Asset Types and Asset Location Types.
For each synchronized feature class define the following:
Custom value mapping extendable lookups for specific GIS field values that may need to be mapped to different values.
A GIS to WAM extendable lookup.
