Batch Processes
The following batch processes need to be run in sequence to load all data from file defined
according to the format mentioned in the File Format section. The below batch sequence
is the same for initial sync or delta changes.
Before initiating the
inbound synchronization, make sure that configuration is done in Master Data Synchronization master configuration record.
Refer to Understanding Data
Synchronization for more information.
Step | Batch Code | Description | Additional Parameters (if any) |
1 | W1GISUPL | GIS File Upload |
fileName: Name of the file or files to be uploaded. For multiple files, the parameter supports the "glob" syntax for using wildcard characters. filePath: The file path where the output should be placed. |
2 | W1-CMSYN | Composite Sync Request | State: PENDING BO: W1-CompositeSyncReqGISAsset |
3 | W1-SIOPE | Ongoing Sync Request - Pending | State: PENDING BO: W1-OngoingSyncRequestLocation |
4 | W1-SIOPE | Ongoing Sync Request - Pending | State: PENDING BO: W1-OngoingSyncRequestAsset |
