Asset Synchronization Batch Processes
Asset inbound synchronization can be performed for an initial synchronization or for delta updates and changes.
Synchronization request records are processed by the synch request monitor batch process, and it is at that time that the actual outbound message is prepared and sent to the external system.
No batch needs to run explicitly for outbound synchronization as the interface dynamically updates the GIS system.
The following sections describe the background processes involved in asset synchronization from the GIS system.
Before initiating the inbound synchronization, make sure that configuration is done in Master Data Synchronization master configuration record. Refer to Understanding Data Synchronization for more information.
