Legacy GIS Batch Controls
The following batch processes need to be run in sequence to load all data from file defined according to the format mentioned in the Configuring Legacy GIS Integration section.
Initial Synchronization
The following batch processes need to be run in sequence to complete the initial load of all eligible assets from the GIS system.
The system keeps track of the status of the initial conversion process in the One-time Data Conversion field of the Esri WAM Integration master configuration record. Until the process is complete, the field shows Convert all Esri data.
Step Batch Code Description Additional Parameters (if any)
1 W1–GISID Retrieve GIS ID’s
2 W1–PRGIS Process GIS Data
3 W1-CMSYN Composite Sync Request State: PENDING
BO: W1-CompositeSyncReqGISAsset
4 F1-SYSRQ Sync Request Monitor (Deferred) State: PENDING
BO: W1-InitialSyncRequestLocation
5 F1-SAKRQ Sync Request Allocate Keys Monitor State: DATA-TRANSFD
6 W1-SIKSP Initial Sync Request - Resolve Keys Loc State: KEY-ALLOCATD
7 W1-SILSP Initial Sync Request - Load Data Location State: KEYS-RESOLVD
8 W1-SILDD Initial Sync Request - Loaded State: LOADED
9 F1-SYSRQ Sync Request Monitor (Deferred) State: PENDING
BO: W1-InitialSyncRequestAsset
10 F1-SAKRQ Sync Request Allocate Keys Monitor State: DATA-TRANSFD
11 W1-SIKAS
Initial Sync Request - Resolve Keys Asset
State: KEY-ALLOCATD
12 W1-SILAS Initial Sync Request - Load Data Asset State: KEYS-RESOLVD
13 W1-SILDD Initial Sync Request - Loaded State: LOADED
14 W1-DELVR GIS Delete Version
Ongoing Synchronization
After the initial conversion is complete, the following batch processes need to be run periodically and in the specified sequence to uptake ongoing delta changes to eligible assets from the GIS system.
4 W1-SIOPE Ongoing Sync Request - Pending State: PENDING
BO: W1-OngoingSyncRequestLocation
5 W1-SIOPE Ongoing Sync Request - Pending State: PENDING
BO: W1-OngoingSyncRequestAsset
6 W1-DELVR GIS Delete Version
