5 Subject Areas
Subject areas are the building blocks of your visualizations and canvases in Opower Analytics Visualization. A visualization is built by choosing an appropriate subject area that has information that answers the business question you’re analyzing.
Technically, subject areas are groupings of information, called data objects, that relate to each other in a particular context. The subject area data comes from data objects pulled from your transactional database. The data is then grouped in a way that is intended to answer a specific set of questions about your organization. Any information your organization tracks can be grouped into a subject area and then used to build analytics.
To open a subject area:
- Log in to your instance of Opower Analytics Visualization.
- Click the navigator menu in the top left corner of the screen and select Data.
- In the Datasets tab, click any of the subject areas available. A new workbook opens. You can browse the folders on the left-hand side of the screen, and you can select and drag attributes or measures to the canvas to begin building visualizations.
The subject areas available are listed below. Additionally, there are shared data elements that appear in most or all subject areas. Most subject areas are available out of the box, but some require a prerequisite cloud service.
- Energy Efficiency (EE) - Savings
- Survey - Questions and Answers
- Survey - Starts and Completions
- Household - Count of Customers
- Opt Out - Products
- Opt Out - Products and Channels
- Outbound Communications - Dispatch and Engagement
- Products - Historical Preferences
- Unauthenticated Home Energy Analysis - HEA
- Web - Authentications
- Web - Pageviews
For more information on how to leverage these subject areas to build visualizations, see Perform Common Tasks or watch the video overviews available in the Oracle Analytics Server online help.
