Defining Failure Profiles
The Failure Profile portal is used to display and maintain failure profiles.
You can access the portal from Admin, select F, then select Failure Profile.
  • Failure Profile List: This zone lists all failure profile records. Broadcast a record to display the details of the selected record.
  • Failure Profile: This zone identifies the selected failure profile.
  • Failure Causes: This zone lists the failure causes associated with this failure profile.
  • Failure Modes: This zone lists the failure modes associated with this failure profile.
  • Failure Repairs: This zone lists the failure repairs associated with this failure profile.
  • Failure Components: This zone lists the failure components associated with this failure profile.
