Defining Overtime Types
The Overtime Type portal is used to display and maintain overtime types.
You can access the portal from Admin, select O, then select Overtime Type.
  • Overtime Type List: This zone lists all labor earning type records. Broadcast a record to display the details of the selected record.
  • Overtime Type: This zone provides information about the selected overtime type.
