Deposit Class - Review Method
On Deposit Class - Main you must define the Review Method Algorithm used by the system to determine what action to take if the system recommends a deposit (or additional deposit) amount for an account.
If you haven't done so already, you must set up this algorithm in the system. To do this:
- Create a new algorithm (refer to Setting Up Algorithms).
- On this algorithm, reference an Algorithm Type that determines the review method the system uses if it recommends a deposit or additional deposit be applied to an account. Click here to see the algorithm types available for this plug-in spot.
