How Does The Overdue Monitor Work?
This section describes how the Overdue Monitor background process (batch control: C1-ADMOV) uses your overdue rules to collect overdue debt.
Recommendation. We recommend that you familiarize
yourself with the concepts described in the case studies before reading this section.
Collecting overdue bills. The examples in the following
section frequently refer to how the Overdue Monitor is configured
for an organization that collects on unpaid bills. It should be noted
that these are just examples as the Overdue Monitor can be used to
collect on virtually anything (if you create the appropriate plug-in
algorithms).
Related Topics:
Parent Topic: Defining Overdue Processing Options
