Engagement Manager Procedures
The Web EMC or Web Configuration Console (WCC) widget enables you to assign one of the following manager procedures to a tile:
Table 45-1 WCC Widget Manager Procedures
| Manager Procedure | Allows You To... |
Edit Header/Trailer |
Edit check headers and trailers for a property or revenue center. If a logo image is available at the Enterprise level from the EMC, you can also add that image to the check header. |
Bulk Edit MI Prices |
Filter and edit menu item prices by revenue center, major group, family group, screen look up (SLU), menu item class, and a keyword entry. |
Copy Menu Item |
Add images to menu items. Add new menu items using existing menu item records as a template. |
Copy Employee |
Add new employees using existing employee records as a template. Add or change an image in an existing employee’s profile. |
- Adding Engagement Manager Procedure Tiles to the Hub Page
- Editing the Check Header and Trailer
- Editing Bulk Menu Item Prices
- Adding an Employee From a Template
- Deactivating an Employee
- Adding or Changing an Employee’s Profile Image
- Adding a New Menu Item Using an Existing Menu Item as a Template
- Adding Images to Menu Items
Related Topics
Parent topic: Engagement Cloud Service
