Editing the Check Header and Trailer
- Sign on to the POS client device, and then tap the Hub function.
- Tap the tile configured for the Edit Header/Trailer manager procedure.
- Select a property or revenue center.
- To edit the header and trailer for guest checks, tap Guest Check.
- To edit the header for a customer receipt, tap Customer Receipt.
- Enter the details to print on the header in the Header text fields, and then enter the details to print on the trailer in the Trailer text fields.
- To insert a logo for the header:
- Select a Header text field, and then tap Insert Image.
- Select a logo from the preview.
- Click Save.
Related Topics
- Adding Engagement Manager Procedure Tiles to the Hub Page
- Editing Bulk Menu Item Prices
- Adding an Employee From a Template
- Deactivating an Employee
- Adding or Changing an Employee’s Profile Image
- Adding a New Menu Item Using an Existing Menu Item as a Template
- Adding Images to Menu Items
- Engagement Manager Procedures
Parent topic: Engagement Manager Procedures
