Adding a New Menu Item Using an Existing Menu Item as a Template Sign on to the POS client device, and then tap the Hub function. Tap the tile configured for the Copy Menu Item manager function. Select a menu item that belongs to the same menu item class and print class that you want to assign to the new menu item, and then tap Copy Menu. Configure the following details for the new menu item: Table 45-3 Configuration Fields for Adding New Menu Items From a Template Field or Option Name Description Menu Item Master Name Enter the new menu item name. Definition Select the appropriate menu item definition. If the menu item that you are using as the template has several definitions, all definitions appear in the list. Menu Item Definition Name Enter the name for the new menu item definition. Price Enter the menu item price. To change the image for the menu item: Tap Change Picture, and then tap Browse Image. Select the new image, and then tap Open. Click Add Menu, and then tap OK to confirm the insertion. Related Topics Adding Engagement Manager Procedure Tiles to the Hub Page Editing the Check Header and Trailer Editing Bulk Menu Item Prices Adding an Employee From a Template Deactivating an Employee Adding or Changing an Employee’s Profile Image Adding Images to Menu Items Engagement Manager Procedures Parent topic: Engagement Manager Procedures
