Overview of creating a synchronization connection using the connection wizard
To help you create a synchronization connection, CIS Administration provides a synchronization connection wizard. Using the pages of the synchronization connection wizard, you:
- Specify how the synchronization connection communicates.
- Specify the Clintrial software database instance with which the synchronization connection communicates.
- Specify the Clintrial software protocol with which the synchronization connection communicates.
- Select the InForm Adapter, trial, and mapping definition used by the synchronization connection.
- Select or define a synchronization schedule, or specify that the synchronization connection does not use a schedule.
- Review and save the definition of the synchronization connection.
