Defining a CPE Reference
To define a CPE Reference:
- Open the Data Mappings window for the Oracle Clinical definition you want to update.
- Right-click the CPE Reference node, and select New CPE Reference.
The InForm Architect application adds a CPE Reference to the CPE References node.
- Set the date and, optionally, the time of the CPE Reference, as described in Defining the date of a CPE Reference and Defining the time of a CPE Reference.
- Select the CPE Reference node and edit the mapping property values in the Properties window, as described in Defining the properties of a CPE Reference.
