Setting Up and Using the Oracle Life Sciences Data Hub
After you design and set up the organizational structure and security and classification systems, you can begin the task of migrating existing programs, tables, views, datasets, and data into Oracle LSH, and creating new applications for analyzing and reporting data. You can then retrieve information from Oracle LSH in the form of reports, data visualizations, and data marts.
Oracle LSH implementation and usage can be divided into four phases, as shown in Figure 2-1. In general, a different set of people in your organization will be involved in each phase, and there is a different Oracle LSH manual for each phase.
After the first phase, you must complete at least a minimal amount of work for each task in any phase before you can proceed to the next phase. You can then work on all the tasks in parallel as necessary.
Figure 2-1 Phases of Oracle LSH Implementation and Use, with User Documentation for Each Phase
Description of "Figure 2-1 Phases of Oracle LSH Implementation and Use, with User Documentation for Each Phase"
Figure 2-1 graphically represents the tasks in each phase and their relation to tasks in the subsequent phases. These relations are also described in the following sections:
