Defining Informative Note Attributes
This section describes the following topics relating to Informative Notes and Informative Note Attributes:
Parent topic: Defining Other TMS Elements
Overview of Informative Notes and Attributes
Informative notes are data structures that you can create to provide more information about a term, relation, VTA, VTI, or dictionary in the database. The advantage that Informative Notes offer over the other detail items—the code, alternate code, category, and the value_1 through value_4 columns—is their flexibility. Using Informative Notes, you can attach a URL, text in a Character Large Object (CLOB), or a note of predefined length containing character, number, mixed, or date data.
Each time you create an Informative Note, you must base it upon an Informative Note Attribute, which gives the note its type, data type, maximum length, and other properties. Using attributes as the basis for Informative Notes saves time during note definition and provides more consistency among the Informative Notes defined in your database.
You can define dictionary-wide Informative Notes that are inherited by all terms in a dictionary. Users can create an Informative Note for a specific term, relation, VTA/VTI, action assignment, or an SMQ algorithm in a filter dictionary such as MedDRA SMQs. See:
Using the Status/Notes Pop-up Window for creating Informative Notes for VTAs, VTIs, and Action Assignments
Parent topic: Defining Informative Note Attributes
Defining an Informative Note Attribute
This section includes:
- Defining Informative Note Attribute Properties
- Defining the Details for the Informative Note Attribute
- Making Informative Note Attributes Available for Dictionaries and Record Types
Launch the Define Informative Note Attributes window by navigating to Definition, then Define Informative Note Attributes. The Define Informative Note Attributes window opens, with the Informative Note Attributes tab selected. This tab shows detailed information about one Informative Note Attribute, and is the window for defining new attributes. Click the Multi Display Informative Note Attributes tab to view several attribute records at once.
The Properties block contains the essential information about the attribute: its name, type, and other settings that control its use in TMS.
![Description of the illustration "tmsdfatt_properties_block.gif" Description of the illustration "tmsdfatt_properties_block.gif"](img/tmsdfatt_properties_block.gif)
To define the attribute's properties, from either tab of the Define Informative Note Attributes window:
Parent topic: Defining an Informative Note Attribute
Attribute details are optional, but you can create a more specific and useful Informative Note Attribute by specifying them for some applications.
![Description of the illustration "tmsdfatt_details_block.gif" Description of the illustration "tmsdfatt_details_block.gif"](img/tmsdfatt_details_block.gif)
To define attribute details:
- Navigate to the Details block on the Informative Note Attributes tab to enter attribute details.
- In the Attribute Code field, enter a mixed-case code to use to link this Informative Note Attribute to an attribute defined in a vendor's dictionary.
- In the Short Name field, you can enter a unique value for the short name of this Informative Note Attribute. TMS allows short names containing up to ten bytes of alphanumeric text. If you leave this field blank and save the record, TMS supplies a default, unique value.
- In the Description field, you can enter user-defined text about this Informative Note Attribute.
- In the LOV Statement field, you can enter the SQL statement you want to use to populate a list of values for Informative Notes based on this attribute. The system limits values to those in the LOV only if you select the LOV Validation? box, described in the above section, Defining Informative Note Attribute Properties.
- Save. TMS commits this Informative Note Attribute to the database, which enables you to create Informative Notes based on this attribute.
Specify the dictionary or dictionaries with which an Informative Note is appropriate for use, and the item—term, relation, term history, dictionary, or filter dictionary algorithm—with which it is appropriate. When users define Informative Notes, the system allows them to select only Informative Note Attributes that you define as appropriate in this window.
