Review and approve a request with the wizard
Self-Service Approval Portal provides a wizard that guides you through the request approval process. The wizard is only available for approval users. Use the wizard to review and approve a request as quickly as possible.
Alternatively, you can perform all the reviews and actions required to approve a request manually, as described in Perform the actions required for approval and Perform the reviews required for approval.
To review and approve a request with the wizard:
- Open the wizard
You can use the wizard to review and approve a request as quickly as possible. The wizard is only available for approval users. - Step 1: Assign Partner
As an approval user, you can use the wizard to assign a self-service site to a partner so that reviewers associated with that site can review the associated request details. - Step 2: Review Site Matches
As an approval user, you can use the wizard to check for a match between the site addresses uploaded by an administrator against the site information in the request. You should not find a match with the site addresses. - Step 3: Review Contact Matches
As an approval user, you can use the wizard to check for a match between the site contacts uploaded by an administrator and the site information in the request. You should not find a match with the site contacts. - Step 4: Review Receiving Hours
As an approval user, you can use the wizard to review and confirm the days and business hours when deliveries will be accepted. - Step 5: Review Documentation
As an approval user, you can use the wizard to review the documents that were uploaded by an administrator or partner. - Step 6: Complete Processing
As an approval user, you can use the wizard to complete the request approval process by choosing to assign the request to a partner for further review, approving, activating, or rejecting the request. You can also exit the wizard without completing the approval process.
Parent topic: Approve requests
