Extract Integration Point
Introduction
This integration point enables bulk extraction of data. It submits and monitors the extraction process.
The submit request starts an extract configuration that begins an asynchronous process to extract data. Upon completion of the extraction process, a pre-configured endpoint receives a notification.
Operations
This specific API supports the following operations
POST
/extracts starts the extraction process.
GET
/extracts/{id} returns the status of the extraction process:.
The Extract Configuration
The extract configuration specifies the criteria to extract data. This includes rows to select, properties, and any linked data not directly part of the resource itself.
The extract configuration comprises:
  • resourceName: The name of the root resource to extract data. For example, policies or ctrclaims.
  • q: The query string for the root resource. It specifies a criteria to select rows. This parameter works similar to the syntax of a query API.
  • fields: The basic and reference fields of a root resource to determine the data to include in the extraction process.
  • expand: The subResource of shorthand keys like dynamicData, rootDynamicData, and subResources to include in the extraction process.
  • linkedResources: Includes extra resources in the extract, not part of the root resource. For example, calculation results along with policies. It can include a list of linked resources of a root resource for the extraction process. The configuration to include a linked resource is similar to that for including a root resource.
    • resourceName: The linked resource name.
    • join: The join criteria to join a linked resource with a root resource. This parameter only supports a subset of query API parameters. Following is the list of parameters that this parameter allows:
    • q: Selects a criteria for the linked resource.
    • fields: Sets the basic and reference type properties of a root resource.
    • expand: Selects properties of a subresources of a linked resource for the extract request.
The Extract Payload
The extract request generates a data file set with multiple files. Each file contains an array of records. Each record is a representation of a row with the linked resources based on the query criteria set for a root resource.
The payload for each selected row contains the root resource and the properties of all the linked resources. The View Objects page contains the resource properties. Each object property has different data types. See Property Representation (GET) for the different representations of a data type.
The property name of an object property matches the name on the View Objects page. The property name works for the fixed properties. The field usage name works for dynamic properties.
The default representation for the extract request includes the following elements:
Table 1. Extract Payload
Element Data Type Included?
Basic Properties
single value
Yes
Reference Properties
single value
No
Dynamic Record
single value
No
Sub resources
No
Basic Properties
multi value
Yes
multi value
No
Dynamic Record
multi value
No
Basic Properties
time valid
No
time valid
No
Dynamic Record
time valid
No
The fields and expand parameters determine the response that includes more information than the default representation.
The Expand Parameter
The expand parameter includes data from subresources.
Consider the following examples:
Table 2. The Expand Parameter
expand value claimLine included? claimLineDiagnosis included? claimDiagnosis included? claimPendReason included? claimLinePendReason included?
not specified
No
No
No
No
No
claimLineList
Yes
No
No
No
No
claimLineList.claimDiagnosesList
Yes
No
Yes
No
No
subResources
Yes
No
Yes
Yes
No
claimLineList.subResources
Yes
Yes
No
No
Yes
The expand parameter includes dynamic records and dynamic fields like subresources or dynamicData.
expand value claim dynamicData included? claimLine dynamicData included? claimDiagnosis dynamic data included? brand dynamicData included? claimLinePendReason dynamicData included?
not specified
No
No
No
No
No
rootDynamicData
Yes
No
No
No
No
subResources
Yes
Yes
Yes
No
No
dynamicData
Yes
Yes [1]
Yes[1]
No
Yes[1]
brand.dynamicData
No
No
No
Yes
No
No
Yes
No
No
Yes
claimLineList.dynamicData
No
Yes
No
No
No
When the representation includes dynamic data in the form of dynamic records or flex codes, each dynamic record or flex code representation includes a GUID field.
The Fields Parameter
The fields parameter determines the additional properties that return in a resource representation of the extract request.
Table 3. Fields Parameter
Fields Value Claim Included? ServicedMember Included? servicedMember.addressList included? claimLineList included?
not specified
Displays all the properties in the default representation
No
No
No
code and id
Includes only code and id
No
No
No
servicedMember
Includes the default representation and a servicedMember reference property
Default representation properties for servicedMember
No
No
addressList sub resource
Includes the default representation for all the addresses
No
claimLineList.id and claimLineList.code
Includes all the properties specified in the default representation
No
No
Only code and id included for all the claimLines
Join Linked Resources
For a join operation, the left side expression is for the root resource and the right side expression is for the linked resource. Following is a syntax used for the join criteria:
join := expression
expression := [[(]simple_expression | complex_expression[)]]
simple_expression := field_name.operator(linked_resource_name.field_name)
operator := eq | neq
field_name := attribute[(+)]?[.field_name]* -- for joins
complex_expression := expression.complex_operator.expression
complex_operator := and | or
  • Join expressions on dynamic fields are not supported.
  • Joining the linked resources to the root resource works as an outer join. If a root resource does not have a corresponding linked resource, it will still be excluded from the extract.
In the following example, the extract is on claims and fetches ctrClaims as a linked resource. The join between ctrClaim and claim is on code.
code.eq("code")
This is an example of a join criteria with a simple expression.
The right expression is for the ctrClaims linked resource and the left expression refers to the claims root resource.
The following example extracts data for policies and different versions of policies along with their linked resources. The join between policies and policies versions is on gid; both IDs are different. Hence, the following join criteria is a complex expression:
gid.eq("gid").and.id.neq("id")
The right expression refers to policies as a linked resource that fetches versions, and the left expression refers to policies as a root resource that considers the latest version.
Notification
The extract request uses the generic notification. A notification key is sent during the submit step of the extract request.
The notification is sent to a pre-configured endpoint and the notification key helps determine whether the extraction process was a success or not.
The ohi.extract.{0}.notification.endpoint property configures the notification endpoint. Here, {0} is the notification key for the extract.
The configured endpoint accepts a POST request.
A data extraction on a gateway uses the gateway as the notification key. The keyword directs the IP to the notification integration point in the gateway.
The notification uses JSON as the default media type. Alternative media types are configured through the REST client’s media type properties. The media type of the notification is set through the ohi.service.{0}.media.type property, where {0} is the notification key for the extract.
Following is an example of a notification:
  "status": "",
  "correlationId": "",
  "links": [
      "rel": "file",
      "href": "http://[hostName]:[portNumber]/[api-context-root]/datafilesets/{datafilesetcode}/datafiles/{datafilecode}/data",
Authentication
The extract notification supports different authentication types for the notification clients. The default value is the basic authentication. The ohi.service.{0}.client.authentication property uses the authentication feature, where {0} is the notification key on the extract, the same as a credential key.
Authorization
A user authorization configuration protects access to this integration point. The relevant access restriction is the extracts IP access restriction.
API Conversation and Interaction
This integration point is a Long-Running Operations Through REST. This section explains an example to extract a resource.
For example, where all claims with a person as a linked resource are joined with a claimLine serviced member. The extract payload contains all the claim and claim line subresources and all the subresources of the person-linked resource. The extract notification is sent to the pre-configured endpoint with the gateway notification key.
The submit request accepts an optional correlationId header. An external system uses a header that matches the request and the notification message. The extraction process stores and includes the header as part of the notification message.
Starting the Extraction Process
A POST request to the /extracts resource starts the extraction process.
Request
Following is an example of the request payload:
header - correlationId: 123
   "notificationKey": "gateway",
   "resourceName": "claims",
   "expand": "subResources|claimLineList.subResources",
   "linkedResources": [
       "resourceName": "persons",
       "join": "claimLineList.servicedMember.code.eq("code")",
       "expand": "subResources"
Response
Following is an example of a response payload:
201
Content-Type: application/vnd.oracle.insurance.resource+json
Vary: Accept,Accept-Encoding,Accept-Language,Origin
X-Content-Type-Options: nosniff
X-Frame-Options: deny
X-OHI-APP-ID: ALI
X-OHI-APP-VERSION: 6.0.0
X-XSS-Protection: 1; mode=block
Location: http://[hostName]:[portNumber]/[api-context-root]/extracts/12324
The application returns an HTTP 201 (Created) response with a location header for the data file set.
Monitoring the Extraction Process
A monitor link helps to monitor the extraction process.
Request Message
A GET request on /extracts/{id} returns the status of the extraction process.
Response Message
The system returns the following response message along with a 200 status for a successful extraction process.
  "status": "InProcess",
  "links": [
        "href": "http://[hostName]:[portNumber]/[api-context-root]/activities/{id}",
        "rel": "operator",
        "httpMethod": "GET"
        "href": "http://[hostName]:[portNumber]/[api-context-root]/extracts/{id}",
        "rel": "monitor",
        "httpMethod": "GET"
Additional links such as operator:restart and operator:messages are available in case of a failed extraction process. Following is an example of a payload that returns for a failed process:
    "status": "TechnicalError",
    "links": [
            "href": "http://[hostName]:[portNumber]/[api-context-root]/activities/234",
            "rel": "operator",
            "httpMethod": "GET"
            "href": "http://[hostName]:[portNumber]/[api-context-root]/activities/234/recover",
            "rel": "operator:restart",
            "httpMethod": "POST"
            "href": "http://[hostName]:[portNumber]/[api-context-root]/activities/234/messages",
            "rel": "operator:messages",
            "httpMethod": "GET"
            "href": "http://[hostName]:[portNumber]/[api-context-root]/extracts/1",
            "rel": "monitor",
            "httpMethod": "GET"
Completion of Extraction Process
The configured endpoint receives a notification after the completion of the extraction process. The location-header link returns the extracted results.
A GET request on the location-header link returns the following response:
    "status": "Success",
    "links": [
            "href": "http://[hostName]:[portNumber]/[api-context-root]/activities/2572368306",
            "rel": "operator",
            "httpMethod": "GET"
            "href": "http://[hostName]:[portNumber]/[api-context-root]/datafilesets/EXT12302",
            "rel": "file",
            "httpMethod": "GET"
The response contains a link to the data file set. The link downloads the extracted data.
1. Dynamic data is only included, if the sub resource itself is included.
