Customer Engagement Loyalty Integration
Customer Engagement Loyalty Integration allows you to register customers in the Oracle Retail Customer Engagement loyalty program. Once a customer is registered in the loyalty program, you can retrieve the customer’s loyalty points and awards balances, accrue points from completed purchases, and redeem awards as a pro-rated merchandise discount on an order.
About loyalty programs: Loyalty programs define the rules used for tracking the purchases of customers belonging to store loyalty programs, usually through a system of points. The loyalty points can then be redeemed for discounts of a fixed amount (though the points alone have no intrinsic value). The discounts can be distributed through the mail as paper coupons, or made available to customers as an award coupon created by the award program associated with the customer’s loyalty card.
The Customer Engagement Loyalty integration retrieves a customer’s loyalty information from Customer Engagement at specific points in Order Administration so users can view a customer’s loyalty card information, current loyalty points, and current award coupons. Communication with Customer Engagement uses the Customer Engagement API Interface; the loyalty information is not stored in Order Administration. Certain activities in Order Administration update the customer’s loyalty account information in Customer Engagement:
- Modern View
the Customer Order List pages can display a prompt for the customer to join loyalty a loyalty program if not already a member.
a Loyalty tab is available at the Customer Order List pages to display the customer’s current loyalty and award programs. Optionally, you can issue points for a loyalty program, or issue an award coupon for an award program.
in Contact Center Order Entry, you can prompt for the customer to join a loyalty program if not already a member. If the customer is already a member of more than one program, you can select a card so that an award from the card can be applied to the order. At the Review step, you can specify the award amount to apply.
- Classic View
at Customer Loyalty Registration Window, you can ask a customer to join the loyalty program; when a customer joins, Customer Engagement generates a card for the customer and creates the customer’s loyalty account.
at the Issue Loyalty Points Window, you can issue points to the customer’s loyalty account; Customer Engagement increases the points in the customer’s loyalty program.
at the Issue Loyalty Coupon Window, you can issue an award coupon to the customer’s loyalty account; Customer Engagement creates the award coupon in the customer’s awards program.l
during order entry (interactive and using the generic order interface), you can apply an award amount to an order. When you accept the order, Customer Engagement subtracts the award amount from the customer’s awards program.
- the Customer Engagement Sales Feed sends sales and return information to Customer Engagement in the Customer Engagement Post POSlog Transaction Message; Customer Engagement increases or decreases the loyalty points from the customer’s loyalty program based on the program rules defined for the customer’s loyalty card in Customer Engagement.
Entitlement Programs are not supported.
Other applications, such as XStore and the web storefront, communicate with Customer Engagement to retrieve and update loyalty account information for the customer. This section explains the Customer Engagement Loyalty integration between Customer Engagement and Order Administration only.In this topic:
- Customer Engagement Loyalty Integration Setup
- Setup in Order Administration for the Customer Engagement Loyalty Integration
- Setup in Customer Engagement for the Customer Engagement Loyalty Integration
- Registering a Customer in the Customer Engagement Loyalty Program
- Reviewing Customer Engagement Loyalty Account Information
- Applying Points to a Customer’s Loyalty Card
- Applying Coupons to a Customer’s Loyalty Card
- Accruing Loyalty Points during Order Processing
- Applying and Redeeming Customer Engagement Awards during Order Processing
- Oracle Retail Customer Engagement APIs used in the Loyalty Integration
For more information: See:
- Customer Engagement Customer Integration for more information on interactively communicating with Customer Engagement to keep customer information in Order Administration in sync with Customer Engagement when Customer Engagement is the system of record for customer information.
- Customer Engagement Batch Customer and Sales Integration for more information on sending merchandise hierarchy, item, customer, sales and return information from Order Administration to Customer Engagement using a batch process. This section also includes Customer Engagement Integration Setup (Sales and Customer).
- Customer Engagement Purchase History Integration for more information on reviewing a customer’s purchase history from Customer Engagement on the Display Purchase History Screen in Order Administration.
- Customer Engagement Customer Wish List Integration for more information on how to review and modify a customer’s wish list from Customer Engagement using the Display Wish List Screen in Order Administration.
- The Customer Engagement Implementation Guide for more information on system configuration properties for Customer Engagement.
- The Customer Engagement Batch Processing and Web Services Guide for more information on the Customer Engagement API interface.
- The Customer Engagement Database Dictionary for more information on the tables in the Customer Engagement database.
- The Customer Engagement User Guide and the JET UI User Guide for more information on using the Customer Engagement application.
Before you can use the Customer Engagement Loyalty Integration, you must complete the required setup.
Required versions: To use the Loyalty Integration with Customer Engagement, you must be on these versions:
- Order Management System version 4.5 or higher, or Order Administration.
- Customer Engagement version 10.5 or higher.
In addition:
- the Customer Engagement Customer Integration and Customer Engagement Purchase History Integration uses version 2.3 of the Customer Services API.
- generating a new loyalty card and assigning it to a customer uses
version 3.1 of the Stored Value Card Transaction Services API.
In order for transactions to process correctly, the Franchisee feature must be disabled in Customer Engagement. - retrieving loyalty and award summary information for all accounts attached to a specified loyalty card uses version 2.1 of the Card Services API.
- issuing loyalty points to a specified loyalty card and retrieving all of the loyalty points account activity for a specified loyalty account uses version 1.2 of the Loyalty Account Services API.
- issuing an award coupon to a specified loyalty card, retrieving all of the award account activity for a specified loyalty account, and automatically redeeming an award coupon for a specified amount uses version 1.2 of the Award Account Services API.
Setup is required in both Order Administration and Customer Engagement.
For more information: See Customer Engagement Integration Setup (Sales and Customer) for more information on the setup required to use the Customer Engagement Sales Feed, and Customer Engagement Customer Integration.
- System Control Values for the Customer Engagement Loyalty Integration
- Secured Feature for the Customer Engagement Loyalty Integration
- Web Service Authentication for Customer Engagement
- Customer Engagement Property Settings
- Menu Options Related to the Customer Engagement Loyalty Integration
| System Control Value | Description |
Select this system control value to automatically display the Enter Loyalty Award Discount Window when you select the Reprice option in order entry. |
Use this field to identify the Customer Engagement organization that maps to your Order Administration company. |
Use this field to define the Customer Engagement location to associate with the Customer Engagement loyalty program. Note: The location code must be numeric to prevent any possible issues displaying a customer’s purchase history in Xstore. |
Select this system control value if you want to use the Customer Engagement Loyalty integration. Important: If you select this system control value:
Select this system control value if you want the system to automatically display the Customer Loyalty Registration Window during order entry and Work with Customers when the sold to customer is not already registered in the Loyalty program. Note: If you select this system control value, the ORCE Customer Integration (L37) system control value must be set to INTERACT, indicating you communicate with Customer Engagement interactively. |
Defines the 5 digit prefix assigned to the Card Definition in Customer Engagement that is used to assign new loyalty cards to sold to customers that join the loyalty program. Note: This setting must match the setting in Customer Engagement; for example, if the card prefix in Customer Engagement is00905, you must enter 00905 in this system control value.
Defines the 2 digit card series number assigned to the Card Definition in Customer Engagement that is used to assign new loyalty cards to sold to customers that join the loyalty program. Note: This setting must match the setting in Customer Engagement; for example, if the card series sequence number in Customer Engagement is02, you must enter 02 in this system control value.
Defines the program used to generate a Loyalty Registration Notification email when a sold to customer joins the loyalty program and is assigned a loyalty card in Customer Engagement. LoyRegNotf is the base program that generates the Loyalty Registration Notification email in HTML format. In this situation, the XML Only flag for the Loyalty Registration Notification email template must be unselected. |
| Secured Feature | Description |
This feature controls whether the Issue Points and Issue Awards options display on the Display Loyalty Account Screen.
If the web services used to process inbound messages to Customer Engagement require web service authentication, you must provide a valid web service authentication user and password in Working with Web Service Authentication (WWSA), or a client ID and client secret if using OAuth. In this situation, when Oracle Retail Order Administration generates a message to send to Customer Engagement it includes the web service authentication information in the HTTP header of the message. See Oracle Retail Omnichannel Web Service Authentication Configuration Guide on My Oracle Support (2728265.1) for more information.
Working with Customer Properties (PROP) contains settings required for integration with Customer Engagement.
| Setting | Description | Example Setting |
ORCE_CUSTOMER_SERVICE_PREFIX |
The system uses this property to build the URL for communication with Customer Engagement using the Customer Servics API. |
https://server:8447/ where: server = the name of your Customer Engagement server 8447 = the port to use on the Customer Engagement server |
ORCE_CUSTOMER_SERVICE_SUFFIX |
The system uses this property, along with
the |
/OrceWebServices/v2_3/CustomerServicesApiService?wsdl where 2_3 is the version of the Customer Services API |
ORCE_SVC_SERVICE_SUFFIX |
the |
/OrceWebServices/v3_1/SvcTransactionServicesApiService?wsdl where 3_1 is the version of the Stored Value Card Transaction Services API |
ORCE_CARD_SERVICE_SUFFIX |
the |
/OrceWebServices/v2_1/CardServicesApiService?wsdl where 2_1 is the version of the Card Services API |
ORCE_LOYALTY_SERVICE_SUFFIX |
the |
/OrceWebServices/v1_2/LoyaltyAccountServicesApiService?wsdl where 1_2 is the version of the Loyalty Account Services API |
ORCE_LOYALTY_AWARD_SERVICE_SUFFIX |
the |
/OrceWebServices/v1_2/AwardAccountServicesApiService?wsdl where 1_2 is the version of the Award Account Services API |
ORCE_LOYALTY_PROMPT_ATTRIBUTE |
Defines the corresponding Customer Engagement custom attribute to identify whether Order Administration should automatically display the Customer Loyalty Registration Window for a customer that is not already assigned to a loyalty card. See Customer Engagement PROMPT_TO_JOIN_LOYALTY Attribute Definition for setup instructions. |
PROMPT_TO_JOIN_LOYALTY |
ORCE_SECURITY_ USER_ID |
The Customer Engagement user ID with Security Group permission included in the Customer Engagement API messages. |
Must be a valid user ID in Customer Engagement that has Security Group permission |
ORCE_LOYALTY_REG_MESSAGE |
The text to display on the Customer Loyalty Registration Window, up to 55 positions. |
Does the customer want to join the loyalty program? |
| Menu Option | Description |
Define default text to include in Oracle Retail Customer Engagement Loyalty Registration Notifications. |
Create the RL (Oracle Retail Customer Engagement Communication Failure) order hold reason code. |
- Order Management System Company > Customer Engagement Organization
- Customer Engagement PROMPT_TO_JOIN_LOYALTY Attribute Definition
- Card Definition
An organization in Customer Engagement corresponds to a company in Order Administration. You associate an Customer Engagement organization with an Order Administration company through the ORCE Organization Descriptor (L50) system control value.
Use the System Configuration option in Customer Engagement to define settings for the Customer Engagement organization that integrates with Order Administration. See the Customer Engagement Implementation Guide for more information on how to define configuration settings for Customer Engagement.
Configuration Settings Required for the Loyalty Integration with Customer Engagement
Select System Configuration in Customer Engagement to define these settings for the organization that integrates with Order Administration.
Default Location ID |
Enter a default location ID of up to 12 positions. |
Account Activity Lookup Limit |
Enter the maximum number of account activity records that can be returned when making any type of account activity lookup request to the Customer Engagement Services server. The default value is 400. If the number of loyalty account transactions
returned to Order Administration exceeds this setting, Order Administration
does not display any activity on the Display Loyalty Account History Screen and instead
displays an error message: |
Card Number Length |
Controls the number of digits in a card number. Must be between 10 and 16. |
Process Loyalty Returns |
Select Yes to process returns to a loyalty account. |
Whenever you makes changes to an organization’s configuration settings, you must use the Deploy option, available at the Customer Engagement System Configuration screen, to deploy the configuration settings.Customer Engagement PROMPT_TO_JOIN_LOYALTY Attribute Definition
In Customer Engagement, use the Attribute Definition screen to create an attribute definition that identifies whether Order Administration should automatically display the Customer Loyalty Registration Window for a customer that is not already assigned to a loyalty card.
The attribute you create must match the entry for the ORCE_LOYALTY_PROMPT_ATTRIBUTE setting in the Customer Engagement Property Settings.See the Attribute Definition section of the Customer Engagement User Guide for detailed instructions.
Required settings: When creating the attribute definition, define the fields as follows:
| Field | Description |
Intended Use |
Select Customer. |
Attribute Name |
Enter the value defined for the ORCE_LOYALTY_PROMPT_ATTRIBUTE setting in the Customer Engagement Property Settings, such as |
Unique |
Leave this check box unselected. |
Description |
Enter a description for the attribute definition. Example: |
Data Type |
Select Character. |
Card Definition
Create a card definition in Customer Engagement to use when assigning new loyalty cards to customers that join the loyalty program.
When creating the card definition:
- the 5 digit card prefix you define must also be entered in the Order Administration ORCE Loyalty Card Prefix (M08) system control value.
- the 2 digit sequence number you define must also be entered in the Order Administration ORCE Loyalty Card Series Sequence Number (M09) system control value.
- make sure you assign the Customer Engagement organization that integrates with Order Administration to the card definition.
For more information: See Card Definitions in the Customer Engagement User Guide for instructions on creating and updating a card definition in Customer Engagement.
Card Series Distribution for Card Definition
Create a card series distribution for the card definition you created. The card series distribution contains one or more batches of cards to be generated and then distributed to customers.
For more information: See Card Series Distribution under Card Definitions in the Customer Engagement User Guide for instructions on creating and updating a card series distribution in Customer Engagement.
Generate and Activate Cards for Card Definition
Generate and activate a set of cards within the card definition.
For more information: See Generate Cards and Activate Cards under Card Definitions in the Customer Engagement User Guide for instructions on generating and activating a set of cards within a card definition.
Programs for Card Definition
Create the following programs for the card definition you created:
- Loyalty program: The loyalty program defines the rules used to track the purchases of customers belonging to the program through a system of points that can then be redeemed for discounts on an order. Example: Create a rule to earn 1 point for each purchase dollar.
- Award program: The award program defines the coupons, or e-wards, that are distributed to the customers belonging to the program. These awards are typically distributed as part of promotions such as birthday or anniversary awards, or they can be made available to customers who have accumulated a certain number of points as part of the loyalty program. Example: Create a rule to issue a $25.00 award coupon each time the customer spends $100.00.
For more information: See Programs in the Customer Engagement User Guide for more information on creating and updating programs for a card definition in Customer Engagement.
Includes:
Enrolling a Customer in Loyalty: Classic View
The system registers a sold to customer in the Customer Engagement loyalty program when you select Yes on the Customer Loyalty Registration Window.
When you select to register the customer in the Customer Engagement loyalty program:
- Order Administration sends a Customer Engagement Loyalty Generate Card Request to Customer Engagement.
- Customer Engagement uses the information in the Loyalty Generate Card Request to associate and activate a new loyalty card for the customer.
- Customer Engagement returns the Customer Engagement Loyalty Generate Card Response to Order Administration, containing the customer’s loyalty card number.
- Order Administration:
- generates a Oracle Retail Customer Engagement Loyalty Registration Notifications email to send to the customer. This email contains the loyalty card number assigned to the customer; see Oracle Retail Customer Engagement Loyalty Registration Notifications for the setup required to generate the notice and see Oracle Retail Customer Engagement Loyalty Registration Notification Sample and Contents for a sample email.
- creates a record in the Customer Note table indicating a Customer
Engagement Loyalty Registration Notice has been sent to the customer:
Loyalty Reg Notice to sflye@EXAMPLE.com. You can review customer notes on the Edit Customer Notes Screen. The note is written even if the system generates the Inbound Order XML Message (CWORDERIN) rather than an actual email, or if the email cannot be relayed if, for example, there is a problem with the destination email address.
- Order Administration sends a Customer Engagement Update Customer
Request to:
- update the ORCE_LOYALTY_PROMPT_ATTRIBUTE setting for the customer to FALSE so that Order Administration will not prompt the customer again to join the Loyalty program.
- update the customer’s birth month and day if it was entered on the Customer Loyalty Registration Window.
- Customer Engagement returns the Update Customer Response indicating whether the update was successful.
- If you advanced to the Customer Loyalty Registration window from
the Customer Selection Screen:
- Order Administration sends a Customer Engagement Loyalty Card Request to Customer Engagement, requesting the details of the loyalty card.
- Customer Engagement returns the details of the loyalty card in the Customer Engagement Loyalty Card Response.
- Order Administration uses the information in the Loyalty Card Response to display the loyalty card number and its associated points and awards on the Customer Selection screen.
Communication failure:
- If you select Yes on the Customer Loyalty Registration
window and a connection could not be made to Customer Engagement,
the system displays an error message similar to the following:
No response from ORCE-card not generated. - If the value in the ORCE Loyalty Card Prefix (M08) or ORCE Loyalty Card Series Sequence Number (M09) system control
value is not valid in Customer Engagement, the system displays an
Use this window to ask a sold to customer to join the Customer Engagement loyalty program.
How to display this screen: This window is available when the Use ORCE Loyalty (M06) system control value is selected, the ORCE Customer Integration (L37) system control value is set to INTERACT, and you:
- Select Loyalty from the Action drop-down menu on the Customer Scan Screen in Work with Customers (WCST) or Order Entry (OEOM).
- Select Loyalty on the Customer Selection Screen after selecting a sold to customer.
- Select Loyalty Account on the Display More Options Screen.
- Select Loyalty Account on the More Customer Sold To Options Screen.
- Select Loyalty on the Third Streamlined Order Inquiry Screen (Order Summary) in Streamlined Order Inquiry (DORI).
When you select the Loyalty option, the system retrieves the sold to customer’s information from Customer Engagement. If Customer Engagement does not find a loyalty card for the customer, the system advances you to the Customer Loyalty Registration Window, where you can select to enroll the customer in the Customer Engagement Loyalty program.
- If Customer Engagement finds a loyalty card assigned to the customer, the system advances you to the Display Loyalty Account Screen. If Customer Engagement finds more than one loyalty card assigned to the customer, the loyalty account information for the first card displays on the screen.
- If a Relate ID is not defined for the customer in the Customer
Sold To table, the system displays an error message similar to the
following:
This customer does not have a Relate ID.Note:
If a Relate ID is not defined for the sold to customer, the Loyalty option does not display on the Third Streamlined Order Inquiry Screen (Order Summary) in Streamlined Order Inquiry (DORI). - If a connection could not be made to Customer Engagement, the
Unable to connect to ORCE.
When this window displays automatically: If the Prompt to Join Loyalty (M07) system control value is selected, this window displays automatically when you:
- Select a sold to customer on the CTI Customer Selection Screen if Customer Engagement does not find a loyalty card for the customer and the customer’s ORCE_LOYALTY_PROMPT_ATTRIBUTE setting in Customer Engagement is TRUE or blank.
- Change a sold to customer in Creating and Updating Sold-to Customers (WCST) if Customer Engagement does not find a loyalty card for the customer and the customer’s ORCE_LOYALTY_PROMPT_ATTRIBUTE setting in Customer Engagement is TRUE or blank.
- Create a sold to customer in Creating and Updating Sold-to Customers (WCST) or Order Entry (OEOM) after the customer is created in Customer
Engagement.
- In Work with Customers, this window automatically displays after the final Accept to create the customer.
- In Order Entry, this window automatically displays after the system validates the customer information and source code on the order and you click Accept.
- Create an order in Order Entry (OEOM) if you do not use the CTI Customer Selection Screen and Customer Engagement does not find a loyalty card for the customer and the customer’s ORCE_LOYALTY_PROMPT_ATTRIBUTE setting in Customer Engagement is TRUE or blank. This window automatically displays after the system validates the customer information and source code on the order and you click Accept.
Loyalty Registration Message (unlabeled field above customer) |
The text defined for the ORCE_LOYALTY_REG_MESSAGE setting in Working with Customer Properties (PROP). |
Customer |
The number, company name, last name, and first name of the sold to customer being asked to join the Customer Engagement loyalty program. |
Birth month/day |
The sold to customer’s birth month and birth day. Valid birth months are: Valid birth days are Note: If you enter a birth month and day on this window, regardless of whether the customer joins the Customer Engagement loyalty program or not, the system updates the birth month and day in the Customer Sold To table. The birth year does not display on the screen; however, it defaults to1900 in the Customer Sold To table unless it has been updated through
the Customer Engagement Customer Integration.
Birth Month: Numeric, 2 positions (01-12 in table); required if you define a birth day. Birth Day: Numeric, 2 positions; required if you define a birth month. Birth Year (in table only): Numeric, 4 positions; optional. |
| Screen Option | Procedure |
Register the customer in the Customer Engagement loyalty program |
Select Yes. See Registering a Customer in the Customer Engagement Loyalty Program. |
Do not register the customer in the Customer Engagement loyalty program, but ask the customer again at a later time |
Select Not Now. |
Do not register the customer in the Customer Engagement loyalty program and do not ask the customer again |
Select Never. The system sends an Add or Update Customer Request to Customer Engagement to update the ORCE_LOYALTY_PROMPT_ATTRIBUTE setting in Customer Engagement to FALSE. |
Enrolling a Customer in Loyalty: Modern View
Prompts are displayed in Modern View at the Customer Order List, Customer Item List and Customer Purchase History List pages, as well as the Review step in Contact Center Order Entry, if:
the Use ORCE Loyalty (M06) and Prompt to Join Loyalty (M07) system control values are selected, and
the customer has an ORCE customer ID and is not already a loyalty member, and has not previously requested to stop prompting for loyalty membership, such as by selecting the Never option at the prompt.
Loyalty prompt options: A prompt to join loyalty is displayed below the customer’s name and customer number, providing the following options:
Never: Do not ask the customer again about joining loyalty. In this case, Order Administration sends a Customer Engagement Update Customer Request to update the ORCE_LOYALTY_PROMPT_ATTRIBUTE setting for the customer to FALSE so that Order Administration will not prompt the customer again to join the Loyalty program.
Not Now: The customer is not joining loyalty now, but can be prompted again in the future. Order Administration does not send an update to Customer Engagement.
Enroll: Enroll the customer in loyalty.
Prompt wording: The ORCE_LOYALTY_REG_MESSAGE property from Working with Customer Properties (PROP) defines the wording of the prompt message. Defaults to Does the customer want to join the loyalty program?
There is also an option to enroll the customer in loyalty at the Customer Loyalty List page in Modern View if the above conditions are met and if the customer is not already enrolled.
When enrollment of the customer is confirmed, the communication with Customer Engagement and updates described above under Enrolling a Customer in Loyalty: Classic View take place
Classic View: Use the following screens to review loyalty account information for a customer that is registered in the Customer Engagement Loyalty program:
- Display Loyalty Account Screen: allows you to review the current points accrued and the awards available to the customer.
- Display Loyalty Account History Screen: allows you to review the points activity and award activity associated with the customer’s loyalty card.
- Customer Selection Screen: allows you to review the loyalty card number, current earned points, and current awards balance assigned to the customer’s loyalty account.
Important:
If the customer is assigned to more than one loyalty card in Customer Engagement, Order Administration Classic View displays loyalty card information for the first card returned from Customer Engagement.Modern View: The Customer Loyalty List page in Modern View displays the customer’s cards, loyalty and awards programs, account numbers, levels, and balances. This page is available by selecting the Loyalty tab at the Customer Order List page. From this page, you can also open the Account Details panel to review details of each account and optionally issue loyalty points or award coupons, with proper authority. See the Modern View online help for more information.
Customer Engagement: You can also review the loyalty account information in Customer Engagement; see Reviewing the Customer’s Loyalty Card in Customer Engagement.
Use this Classic View screen to review the current points accrued and the awards available for the loyalty program and award program associated with the customer’s loyalty card.
When you advance to the Display Loyalty Account screen:
- Order Administration sends a Get Customer Request to Customer Engagement containing the customer’s Relate ID from the Customer Sold To table.
- Customer Engagement uses the Relate ID in the Get Customer Request to find the customer and returns the Get Customer Response containing the customer’s information, including the customer’s cards.
- Order Administration sends a Customer Engagement Loyalty Card Request to Customer Engagement containing the customer’s card number.
- Customer Engagement uses the customer’s card number in the Loyalty Card Request to retrieve the loyalty points and awards for the loyalty program and award program associated with the customer’s loyalty card.
- Customer Engagement returns the Customer Engagement Loyalty Card Response to Order Administration, containing the customer’s loyalty account information.
- Order Administration displays the loyalty account information returned from Customer Engagement on the Display Loyalty Account screen.
How to display this screen: This screen is available when the Use ORCE Loyalty (M06) system control value is selected and you:
When you select the Loyalty option, the system retrieves the sold to customer’s information from Customer Engagement. If Customer Engagement finds a loyalty card assigned to the customer, the system advances you to the Display Loyalty Account Screen. If Customer Engagement finds more than one loyalty card assigned to the customer, the loyalty account information for the first card returned displays on the screen.
- If Customer Engagement does not find a loyalty card for the customer, the system advances you to the Customer Loyalty Registration Window, where you can select to enroll the customer in the Customer Engagement Loyalty program.
following:
Column sort: You can sort on the Coupon ID, Coupon Amount, and Expiration Date columns on this screen by clicking on the column name. An arrow pointing up displays next to the field when the values for the field display in ascending sequence; an arrow pointing down displays next to the field when the values for the field display in descending sequence.
The information that displays on this screen is from Customer Engagement and is not stored in Order Administration.
Customer # |
The number, company name, last name, and first name of the sold to customer registered in the Customer Engagement Loyalty program. Customer number: Numeric, 9 positions; display-only. Customer name: Alphanumeric, 40 positions; display-only. |
Loyalty Card # |
The loyalty card number assigned to the customer in Customer Engagement. The points and awards associated with this card display on the screen. From cardNumber in the Customer Engagement Loyalty Card Response. |
Loyalty Points The loyalty points for the loyalty program associated with the customer’s loyalty card. Only loyalty points from Customer Engagement display on this screen; escrow and bonus points from Customer Engagement do not display. |
Current Points |
The total current earned points balance for the customer loyalty account. From EARNED points value in the Customer Engagement Loyalty Card Response. |
Points Earned This Year |
The total earned points balance for the current year for the customer’s loyalty account. From YTD points value in the Customer Engagement Loyalty Card Response. |
Total Points Earned |
The total lifetime earned points balance for the customer’s loyalty account. From LTD points value in the Customer Engagement Loyalty Card Response. |
Program Level |
A description of the current level of the loyalty program to which the customer’s loyalty account is assigned. From loyaltyProgramLevel value in the Customer Engagement Loyalty Card Response. |
Current Awards |
Coupon ID |
The ID number for the coupon created or redeemed by the award activity. From coupon id in the Customer Engagement Loyalty Card Response. |
Amount |
The amount of the coupon applied to the customer’s award account by the activity. From coupon amount in the Customer Engagement Loyalty Card Response. |
Expiration Date |
The date when the coupon expires.
From coupon ExpirationDate in the Customer Engagement Loyalty Card Response. |
Review loyalty account history |
Select Loyalty History to advance to the Display Loyalty Account History Screen. |
Issue points |
Select Issue Points to advance to the Issue Loyalty Points Window. Note: This option is available only if you have authority to the ORCE Issue Awards/Points (J07) secured feature. |
Issue awards |
Select Issue Awards to advance to the Issue Loyalty Coupon Window. Note: This option is available only if you have authority to the ORCE Issue Awards/Points (J07) secured feature. |
Use this screen to review points activity and award activity for the loyalty program and award program associated with the customer’s loyalty card.
When you advance to the Display Loyalty Account History screen:
- Order Administration sends a Customer Engagement Get Customer Request to Customer Engagement containing the customer’s Relate ID from the Customer Sold To table.
- Customer Engagement uses the Relate ID in the Get Customer Request to find the customer.
- Customer Engagement returns the Customer Engagement Get Customer Response to Order Administration, containing the customer’s information, along with the customer’s loyalty card information.
- Customer Engagement uses the customer’s card number in the Loyalty Card Request to retrieve the loyalty account and award account associated with the customer’s loyalty card.
- Customer Engagement returns the Customer Engagement Loyalty Card Response to Order Administration, containing the customer’s loyalty account and award account information.
- Order Administration sends a Customer Engagement Loyalty Account History Request and Customer Engagement Award Account History Request to Customer Engagement.
- Customer Engagement uses the information in the Loyalty Account History Request and Award Account History Request to retrieve the customer’s loyalty account and award account activity.
- Customer Engagement returns the Customer Engagement Loyalty Account History Response and Customer Engagement Award Account History Response to Order Administration, containing the customer’s loyalty account and award account activity.
- Order Administration displays the loyalty account and award account activity returned from Customer Engagement on the Display Loyalty Account History screen.
- If Customer Engagement finds more than one loyalty card assigned to the customer, the loyalty account information for the first card returned displays on the screen.
- Order Administration does not display
Inquirytype transactions on the screen. - If the number of loyalty account transactions returned exceeds
the Account Activity Lookup Limit setting in Customer
Engagement, the system does not display any activity on the Display
Loyalty Account History screen and instead displays an error message:
Max results value defined in ORCE has been exceeded.
How to display this screen: Select Loyalty History on the Display Loyalty Account Screen.
The information that displays on this screen in from Customer Engagement. Activity transactions display in descending activity date sequence.
Customer # |
Loyalty Card # |
Loyalty Account History |
Activity Date |
The date and time when the loyalty points or award coupon activity occurred. Note: The time for loyalty points activity always displays as 12:00:00.Loyalty account: From businessDate in the Customer Engagement Loyalty Account History Response. Award account: From activityDateTime in the Customer Engagement Award Account History Response. |
Activity |
The type of activity that occurred against the card. Points Activity
Awards Activity
Loyalty account: From transactionType in the Customer Engagement Loyalty Account History Response. Award account: From transactionType in the Customer Engagement Award Account History Response. |
Award Effect |
The effect of the awards activity. Positive Awards Activity A positive amount displays if the awards activity increased the awards amount on the loyalty card.
Negative Awards Activity Automatic Redeem A negative amount displays if the awards activity decreased the awards amount on the loyalty card.
No Effect (Positive or Negative) Awards Activity
Note: This field is blank for loyalty account activity.From activityAmount in the Customer Engagement Award Account History Response. |
Point Effect |
The effect of the points activity. Activities that Add Points to the Loyalty Card
Activities that Subtract Points from the Loyalty Card
Activities that have No Effect on Loyalty Points
Note: This field is blank for award account activity.From numPoints in the Customer Engagement Loyalty Account History Response. |
Pending |
Yes displays if the points are pending being issued; otherwise this field is blank. Note: This field is blank for award account activity.From pendingFlag in the Customer Engagement Loyalty Account History Response. |
Location ID |
The location ID associated with the transaction. Loyalty account: From locationId in the Customer Engagement Loyalty Account History Response. Award account: From locationId in the Customer Engagement Award Account History Response. |
Activity ID |
The activity transaction ID assigned to the transaction in Customer Engagement. You can use this value as a reference for voiding a transaction in Customer Engagement or when writing a customer or order note. Loyalty account: From accountActivityId in the Customer Engagement Loyalty Account History Response. Award account: From awardTranId in the Customer Engagement Award Account History Response. |
Use the following screens in Customer Engagement to review the loyalty card assigned to the customer.
Customer Dashboard: The Card / Accounts section of the Customer Dashboard displays the card number generated for the customer and information about the loyalty program and award program associated with the customer’s card.
Card / Account Administration Screen: The Card / Account Association screen displays information about the card assigned to the customer.
- Selecting the Award account on the Card / Account Association screen displays basic information and activity for the award program associated with the card. You can click on a transaction to display additional information about the activity.
- Selecting the Loyalty account on the Card / Account Association screen displays basic information and activity for the loyalty program associated with the card. You can click on a transaction to display additional information about the activity.
Use the Issue Loyalty Points window to issue points to the loyalty program assigned to the customer’s card.
Modern View: The option to issue points is also available in Modern View at the Account Details panel from the customer order list page, requiring authority to the same secured feature as Classic View.
How to display this screen: Select Issue Points on the Display Loyalty Account Screen. You must have authority to the ORCE Issue Awards/Points (J07) secured feature to advance to this window.
Loyalty Card # |
The loyalty card number assigned to the customer in Customer Engagement to which you wish to issue points. This is the card number that displays on the Display Loyalty Account Screen. Display-only. |
Points Amount |
The number of points to issue. Updates the earned points balance for the customer’s loyalty account in Customer Engagement. Numeric, 7 positions with a 2-place decimal; Required. |
Comments |
An informational field to describe the points being issued. Alphanumeric, 1000 positions; Required. |
To issue points:
- Enter a Points Amount and Comments.
- Click OK.
When you click OK:
- Order Administration generates a Customer Engagement Issue Points Request to Customer Engagement containing the loyalty card information and the loyalty points to issue.
- Customer Engagement receives the request and adds the loyalty points to the customer’s loyalty account.
- Customer Engagement generates a Customer Engagement Issue Points Response to Order Administration.
- Order Administration generates a Customer Engagement Loyalty Card Request containing the customer’s card number.
- Customer Engagement receives the Loyalty Card Request and returns a Customer Engagement Loyalty Card Response containing information on the customer’s card, current points balances and current award coupons.
- Order Administration returns you to the Display Loyalty Account Screen. The Current Points, Points Earned This Year, and Total Points Earned fields will include the new points issued.
If a connection could not be made to Customer Engagement, the system displays an error message:Unable to connect to ORCE.
Reviewing the issue points transaction in Customer Engagement: You can review the issue points transaction in Customer Engagement by selecting the Loyalty account on the Card / Account Association screen; activity for the loyalty program associated with the card displays at the bottom of the screen.
Click on the issue points transaction to advance to the Activity Detail window where you can review the details of the transaction.
Use the Issue Loyalty Coupon window to issue an award coupon to the award program assigned to the customer’s card.
Modern View: The option to issue an award coupon is also available in Modern View at the Account Details panel from the customer order list page, requiring authority to the same secured feature as Classic View.
How to display this screen: Select Issue Awards on the Display Loyalty Account Screen. You must have authority to the ORCE Issue Awards/Points (J07) secured feature to advance to this window.
Loyalty Card # |
The loyalty card number assigned to the customer in Customer Engagement. This is the card number that displays on the Display Loyalty Account Screen. Display-only. |
Award Amount |
The amount to assign to the award coupon. Updates the award balance for the customer’s award account in Customer Engagement. Numeric, 7 positions with a 2-place decimal; Required. |
Expiration Date |
The date when the award coupon expires. The expiration date you enter must be greater than the current date. If you do not define an expiration date, the award coupon uses the award program rules defined in Customer Engagement. Optional. |
Comments |
An informational field to describe the award coupon being issued. Alphanumeric, 1000 positions; Required. |
To issue an award coupon:
- Enter an Award Amount and Comments.
- Optionally, enter an Expiration Date.
- Click OK.
When you click OK:
- Order Administration generates a Customer Engagement Issue Coupon Request to Customer Engagement containing the loyalty card information and the award coupon amount to issue.
- Customer Engagement receives the request and adds the award coupon for the specified amount to the customer’s award account.
- Customer Engagement generates a Customer Engagement Issue Coupon Response to Order Administration.
- Order Administration returns you to the Display Loyalty Account Screen. The Current Awards section of the screen will include the new award coupon issued.
Reviewing the issue coupon transaction in Customer Engagement: You can review the issue coupon transaction in Customer Engagement by selecting the Award account on the Card / Account Association screen; activity for the award program associated with the card displays at the bottom of the screen.
Click on the issue coupon transaction to advance to the Activity Detail window where you can review the details of the transaction.
Customers enrolled in the Customer Engagement loyalty program accrue points from completed purchases based on the program rules defined for the loyalty account in Customer Engagement.
When you send sales and return information to Customer Engagement in the Customer Engagement Post POSlog Transaction Message during the Customer Engagement Sales Feed, Customer Engagement:
- determines the loyalty account to accrue points against based on the customer passed in the Customer Engagement Post POSlog Transaction message.
- for sales transactions, increases the loyalty points on the customer’s loyalty account based on the program rules defined for the loyalty account in Customer Engagement.
- for return transactions, decreases the loyalty points on the customer’s loyalty account based on the program rules defined for the loyalty account in Customer Engagement.
Example: The issue rule defined for the customer’s loyalty program in Customer Engagement is to issue 1 point for each purchase dollar.
The customer has 155 earned points in Customer Engagement.
The customer places an order for $80.00.
When you run the Customer Engagement Sales Feed to update Customer Engagement with the sales and return information in the Customer Engagement Post POSlog Transaction Message, Customer Engagement increases the customer’s earned loyalty points to $235.00 (155 earned points + 80 points associated with sales).
The customer returns an item for $30.00.
When you run the Customer Engagement Sales Feed to update Customer Engagement with the sales and return information in the Customer Engagement Post POSlog Transaction Message, Customer Engagement decreases the customer’s earned loyalty points to $205.00 (235 earned points - 30 points associated with returns).
For more information: See Issue Rule in the Customer Engagement User Guide for more information on defining rules for a loyalty program.
You can apply an award amount to an order as a pro-rated merchandise discount and redeem the award amount applied to the order in Customer Engagement.
- Applying Awards during Interactive Order Entry (Classic View)
- Applying Awards during the Generic Order Interface (Order API)
- Combining the Loyalty Award Amount with Other Discounts
- Loyalty Award Discount Calculations
- Redeeming Awards during Order Processing
- If Communication Fails during Coupon Redemption
- You can apply an award amount to an order during order creation only; you cannot apply an award amount to an order in order maintenance.
- You can apply an award amount to a pre-order quote; however, the award amount is not redeemed until you convert the quote to an order. When you convert the quote to an order, the system allows you to change the award amount for the order before you accept the order and redeem the award amount. See Entering Pre-Order Quotes and Converting Quotes to Orders for more information about quote processing.
- Canceling an order or order line associated with a redeemed award amount does not increase a customer’s award balance. You must issue points or awards to the customer’s loyalty card manually; see Applying Points to a Customer’s Loyalty Card and Applying Coupons to a Customer’s Loyalty Card.
Applying Awards during Contact Center Order Entry (Modern View)
The option to apply an award amount to an order is available in Contact Center Order Entry at the Review step, through the Apply Awards window. You can specify an awards amount to apply for each displayed awards program. The Order Summary panel on the right displays the total value of awards that are available to apply to the order.
If the customer has more than one loyalty card, the Select Card window opens automatically when you advance to the Items step so you can select the card to use when applying any awards to the order. Optionally, you can change your loyalty card selection at the Items, Shipping, or Review step.
Use the following steps to apply an award amount to an order during interactive Order Entry.
To apply an award amount to the order: On the Enter Loyalty Award Discount Window, enter the award amount to apply to the order and click OK. The system applies the award amount as a pro-rated merchandise discount. The discount is applied to all discountable order lines, including order lines that contain a price override reason code.
- The award amount does not apply to order lines that contain a non-discountable item or to sale items if the Exclude Sale Item When Prorating Discounts (I65) system control value is selected.
- If the entered award amount is greater than the discountable merchandise
amount on the order, the system displays a message similar to the
following:
Award amount cannot exceed discountable merchandise. - If the entered award amount is greater than the current awards
balance for the loyalty card, the system displays a message similar
to the following:
Award amount cannot exceed remaining balance. - If more than one order ship to exists on the order, the system applies the award amount to the selected order ship to only.
- The system updates the Customer Engagement Award Amount in the Order Ship To table with the award amount applied to the order.
- The system includes the award amount in the Discount field on the order.
Use this window to apply a coupon award amount as a pro-rated merchandise discount during order repricing.
This window is available during order entry only; this window is not available during order maintenance.How to display this screen: Select Reprice during order entry. The system displays the Enter Loyalty Award Discount Window if:
- the Use ORCE Loyalty (M06) system control value is selected, and
- the Prorate Dollar Discounts and Coupons (D90) system control value is selected, and
- the Price Method for the source code on the order header is set to Reg Plus Reprice, and
- the sold to customer on the order is assigned to a loyalty card in Customer Engagement, and
- there are current awards associated with the customer’s loyalty account that are available for redemption.
Loyalty Card # |
The loyalty card number assigned to the customer that is associated with the awards balance. Note: If the customer is assigned to more than one loyalty card in Customer Engagement, Order Administration displays loyalty card information for the first card returned from Customer Engagement.Display-only. |
Available awards balance |
The total current awards balance for the loyalty card. Display-only. |
Max award amount allowed |
The maximum award amount that can be applied
to the order. Display-only. |
Enter award amount to apply |
The award amount to apply to the order as a pro-rated merchandise discount. A message similar to the
following displays if you enter an award amount that is greater than
the Available awards balance: A message similar
to the following displays if you enter an award amount that is greater
than the merchandise amount: Numeric, 7 positions with a 2-place decimal; Optional. |
For more information: See Combining the Loyalty Award Amount with Other Discounts and Loyalty Award Discount Calculations for more information on how the award amount is applied to the order.
Use the following steps to apply a coupon award amount to a web order.
To apply an award amount to the order: Enter the award amount to apply to the order in the relate_award_amount tag included in the ShipTo element of the Inbound Order XML Message (CWORDERIN).
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
When Order Administration processes the CWOrderIn message, the system determines if the order is eligible for the relate award amount.
Does the sold to customer have a loyalty card? The system verifies that the customer in Customer Engagement has a loyalty card.
If the Customer Engagement customer does not have a loyalty card, the system does not apply the award amount to the order and creates a record in the Order Transaction History table for the order indicating the award amount was not redeemed on the order. For example:
| Date | Type | Transaction Note | Amount | User |
3/06 |
SYSTEM UPDATE |
Award amt not redeemed-card# not found |
10.00 |
your default user |
Is prorating dollar discounts and coupons enabled? The system applies the award amount defined in the relate_award_amount tag to the order only if the Prorate Dollar Discounts and Coupons (D90) system control value is selected.
Does the customer’s award balance cover the relate_award_amount? If the Customer Engagement customer has a loyalty card, the system determines if the award balance for the loyalty card is equal to or greater than the relate_award_amount entered on the order.
- If the award balance is 0.00 or less, the system does not apply the award amount to the order and creates a record in the Order Transaction History table for the order indicating the award amount was not redeemed on the order. For example:
3/06 |
SYSTEM UPDATE |
Award amt not redeemed-award balance=0 |
25.00 |
your default user |
- If the award balance is less than the relate_award_amount, the system applies the available award balance to the order as a pro-rated merchandise discount. For example, if the relate_award_amount on the order is 25.00, but the award balance is $5.00, the system applies 5.00 to the order. The system creates a record in the Order Transaction History table for the order indicating the award amount that was redeemed on the order. For example:
3/06 |
UPSELL PROMO |
Total Prorated Order Level Discount |
5.00 |
SFLYE |
3/06 |
UPSELL PROMO |
Award Redeemed-ID: S444399 |
5.00 |
SFLYE |
- If the award balance is equal to or greater than the relate_award_amount, the system applies the entire award amount to the order as a pro-rated merchandise discount. The system creates a record in the Order Transaction History table for the order indicating the award amount that was redeemed on the order. For example:
3/06 |
UPSELL PROMO |
25.00 |
SFLYE |
3/06 |
UPSELL PROMO |
25.00 |
SFLYE |
The award amount is applied as a pro-rated merchandise discount to all discountable order lines, including order lines that contain a price override reason code.
- The award discount does not apply to order lines that contain a non-discountable item or to sale items if the Exclude Sale Item When Prorating Discounts (I65) system control value is selected.
- If the discountable merchandise amount is less than the entered award amount, the system decreases the Customer Engagement Award Amount in the Order Ship To table to match the discountable merchandise amount. If the discountable merchandise amount is 0.00 or a negative amount, the system updates the Customer Engagement Award Amount in the Order Ship To table to 0.00.
- If you send a subsequent Inbound Order XML Message (CWORDERIN) to complete a web order with payment information or update an order with errors, in order to apply the relate_award_amount to the order, the payment_only flag for the subsequent message must be set to N so that the Order API program deletes the existing order and recreates it using the information provided in the inbound message. It is important that the subsequent message include all information required to complete the order, or the information that was not included in the subsequent message will be lost.
The loyalty award amount is applied as a pro-rated merchandise discount AFTER order detail coupons and any line level promotions have been applied to the lines on the order.
If the merchandise amount after applying discounts is less than the loyalty award amount to apply to the order, the system automatically adjusts the loyalty award amount so that the amount is equal to the discounted merchandise amount.
The system uses the following calculations to determine the award discount amount to apply to each order line.
The system calculates the Discount Percentage for each order line:
Order line extended amount after applying order detail
coupons and line level promotions / order merchandise total = discount
percentage
The system calculates the Unit Selling Price for each order line:
order line post-discount unit price - [(total award amount
X discount % from above calculation) / line unit quantity] = unit
selling price
Example 1: Award Amount Only
An order has the following order lines:
- line 1: 1 unit for 50.00
- line 2: 1 unit for 10.00 (non-discountable)
- line 3: 1 unit for 10.00
The merchandise total is 70.00, 60.00 of which is discountable.
The system applies a 10.00 loyalty award amount to the order.
The system calculates the discount percentage for each eligible order line:
line 1: 50.00 / 60.00 = .833 x 100 = 83.33% discount percentage
line 3: 10.00 / 60.00 = .166 x 100 = 16.66% discount percentage
The system calculates the unit selling price for each order line:
line 1: 10.00 loyalty award amount x 83.33% discount percentage
= 8.33
8.33 / 1 line unit quantity = 8.33
50.00 unit price - 8.33 = 41.67 unit selling price
line 3: 10.00 loyalty award amount x 16.66% discount percentage
= 1.666
1.666 / 1 line unit quantity = 1.666
10.00 unit price - 1.66 = 8.33 unit selling price
The merchandise total after applying the loyalty award amount is 60.00 (line 1 41.67 + line 2 10.00 + line 3 8.33).
Example 2: Award Amount with Line Level Promotion
The system applies a 5.00 line level promotion and 10.00 loyalty award amount to the order.
line 1: 15.00 (line level promotion + loyalty award amount)
x 83.33% discount percentage = 12.50
12.50 / 1 line unit quantity = 12.50
50.00 unit price - 12.50 = 37.50 unit selling price
line 3: 15.00 line level promotion + loyalty award amount
x 16.66% discount percentage = 2.50
2.50 / 1 line unit quantity = 2.50
10.00 unit price - 2.50 = 7.50 unit selling price
The merchandise total after applying the line level promotion and loyalty award amount is 55.00 (line 1 37.50 + line 2 10.00 + line 3 7.50).
Example 3: Award Amount with Order Level Coupon
The system applies a 50.00 loyalty award amount and 20.00 order level coupon to the order.
line 1: 70.00 (loyalty award amount + 20.00 order level
coupon) x 83.33% discount percentage = 58.33
58.33 / 1 line unit quantity = 58.33
50.00 unit price - 58.33 = -8.33 unit selling price (the
system updates the price of the line to .00)
line 3: 70.00 (loyalty award amount + 20.00 order level
coupon) x 16.66% discount percentage = 11.66
11.66 / 1 line unit quantity = 11.66
10.00 unit price - 11.66 = -1.66 unit selling price (the
The merchandise total after applying the order level coupon and loyalty award amount is 10.00 (line 1 .00 + line 2 10.00 + line 3 .00).
Since the merchandise amount after applying discounts is less than the loyalty award amount to apply to the order, the system automatically adjusts the loyalty award amount so that the amount is equal to the discounted merchandise amount; in this example, the system adjusts the loyalty award amount to 40.00 (20.00 coupon amount + 40.00 loyalty award amount = 60.00 total discount, which matches the merchandise amount that is eligible for discount).
To redeem the award amount applied to the order: During the final order accept process, if an award amount is defined on the order, the system:
- sends a Customer Engagement Automatic Redeem Request to Customer Engagement for the award amount applied to the order.
- Customer Engagement redeems award coupons associated with the
customer’s loyalty account until the award amount applied to the order
has been reached.
- Customer Engagement redeems coupons whose expiration date is closest to expiring first.
- If the award coupon amount is greater than the amount to redeem, Customer Engagement subtracts the redeemed amount from the coupon; for example, if the award coupon amount is $100.00 and the amount to redeem is $15.00, Customer Engagement updates the award coupon amount to $85.00.
- Customer Engagement subtracts the amount to redeem from the customer’s award balance.
- Customer Engagement sends a Customer Engagement Automatic Redeem Response to Order Administration.
- Order Administration creates a record in the Order Transaction History table for the order indicating the award amount that was redeemed. For example:
3/06 |
UPSELL PROMO |
10.00 |
SFLYE |
3/06 |
UPSELL PROMO |
10.00 |
SFLYE |
You can display order history by selecting Order History in standard order inquiry or at the Work with Order Lines screen in Order Maintenance, or by selecting History in streamlined order inquiry. See the Display Order Line History Screen for more information.
- updates the Award Amount in the Order Ship To table with the award amount applied to the order.
If communication fails: See If Communication Fails during Coupon Redemption.
Reviewing the automatic redeem transaction in Customer Engagement: You can review the automatic redeem transaction in Customer Engagement by selecting the Award account on the Card / Account Association screen; activity for the award program associated with the card displays at the bottom of the screen.
Click on the automatic redeem transaction to advance to the Activity Detail window where you can review the details of the transaction.
If Order Administration cannot connect with Customer Engagement
to redeem the award amount applied to an order, the system places
the order on RL ORCE Communication Failure hold and writes an order
transaction history message indicating the award amount was not automatically
redeemed: SYSTEM UPDATE ORCE Loyalty Award Redemption Failed
20.00, where 20.00 is the award amount applied
to the order.
In this situation, you can either:
- log in to Customer Engagement and void coupons until the award amount applied to the order is covered. If the amount voided is greater than the amount needed for redemption (for example, the amount applied to the order was $20.00 and you voided a $25.00 award coupon), you can issue a new award coupon for the difference (in this example, $5.00).
- cancel the order and create a new order with the award amount, making sure communication with Customer Engagement during the redemption process is successful.
The following Customer Engagement APIs are used to communicate with Customer Engagement during the Customer Engagement Loyalty integration:
- Customer Engagement Customer Services API v2.3: used to interactively create and update customer information between Customer Engagement and Order Administration; see the Customer Engagement Customer Integration for more information.
- Customer Engagement Stored Value Card Transaction Services
API v3.1: used to generate a new loyalty card and assigns it
to a customer.
In order for transactions to process correctly, the Franchisee feature must be disabled in Customer Engagement. - Customer Engagement Card Services v2.1 API: used to retrieve loyalty and award summary information for all accounts attached to the specified loyalty card number.
- Customer Engagement Loyalty Account Services v1.2 API: used to:
- issue points to the loyalty account specified.
- retrieve all of the loyalty points account activity for the loyalty account specified.
- Customer Engagement Award Account Services v1.2 API: used to:
- issue an award coupon to the loyalty account specified.
- automatically redeem award coupons for the specified amount.
- retrieve all of the award coupon account activity for the loyalty account specified.
ORCE log: Order Administration logs the loyalty transactions passed between Order Administration and Customer Engagement in the ORCE (Oracle Retail Customer Engagement) Log.
Web service authentication? If the web services used to process inbound messages to Customer Engagement require web service authentication, you must provide a valid web service authentication user and password in Working with Web Service Authentication (WWSA), or client ID and secret if using OAuth. In this situation, when Oracle Retail Order Administration generates a message to send to Customer Engagement it includes the web service authentication information in the HTTP header of the message. See Oracle Retail Omnichannel Web Service Authentication Configuration Guide on My Oracle Support (2728265.1) for more information.
For more information: See the Customer Engagement Batch Processing and Web Services Guide for more information on the Customer Engagement API interface.
Customer Engagement Stored Value Card Transaction Services API v3.1
Order Administration calls the Customer Engagement Stored Value Card Transaction Services API version 3.1 to generate the Customer Engagement generateCard Method.
The system uses the value in the ORCE Organization Descriptor (L50) along with the ORCE_CUSTOMER_SERVICE_PREFIX and ORCE_SVC_SERVICE_SUFFIX settings in Working with Customer Properties (PROP) to build the URL for communication with Customer Engagement.
In order for transactions to process correctly, the Franchisee feature must be disabled in Customer Engagement.Customer Engagement generateCard Method
The generateCard method generates a new loyalty card and assigns it to a customer.
When called? The system calls this method when you select Yes on the Customer Loyalty Registration Window, or when you enroll a customer in loyalty in Modern View.
Order Administration sends the following information to Customer Engagement.
| Information | Description |
card Prefix |
The card prefix associated with the Loyalty Card Definition in Customer Engagement; this is the card prefix defined in the ORCE Loyalty Card Prefix (M08) system control value. |
card Series Sequence |
The card series sequence number associated with the Loyalty Card Definition in Customer Engagement; this is the card series sequence number defined in the ORCE Loyalty Card Series Sequence Number (M09) system control value. |
location Id |
The location ID associated with the loyalty program; this is the location defined in the Default Location for ORCE Integration (K69) system control value. If you do not define a location in the Default Location for Sales Download (K69) system control value, Customer Engagement uses the location defined in the Default Location ID system configuration setting. |
currency Id |
The currency code defined in the Local Currency Code (A55) system control value. This system control value must be set to a valid currency code. This system control value must be set to a valid currency code. |
customer ID |
The Customer Engagement customer ID to assign to the loyalty card; this is the Relate ID defined for the customer in the Customer Sold To table. |
security User ID |
The user ID defined in the ORCE_SECURITY_USER_ID property |
The generateCard method returns a GenCardResponseContainerType element. Customer Engagement sends the following information to Order Administration.
dateTime |
The date and time when the response was generated. |
cardSeries |
CardPrefix |
The card prefix associated with the Loyalty Card Definition in Customer Engagement. |
CardSeriesSequence |
The card series sequence number associated with the Loyalty Card Definition in Customer Engagement. |
Instrument |
CardName |
The name of the Loyalty Card Definition in Customer Engagement. |
CardNumber |
The loyalty card number assigned to the customer in Customer Engagement. |
BatchNumber |
The batch number associated with the loyalty card in Customer Engagement. |
Customer |
CustomerID |
The Customer Engagement customer ID assigned to the loyalty card. |
Order Administration calls the Customer Engagement Card Services to generate the Customer Engagement getCardInquiryData Method.
The system uses the value in the ORCE Organization Descriptor (L50) along with the ORCE_CUSTOMER_SERVICE_PREFIX and ORCE_CARD_SERVICE_SUFFIX settings in Working with Customer Properties (PROP) to build the URL for communication with Customer Engagement.
The getCardInquiryData method retrieves loyalty and award summary information for all accounts attached to the specified loyalty card number.
When called? The system calls this method when you:
- advance to the Display Loyalty Account Screen to review the customer’s loyalty points and award coupons.
- advance to the Customer Selection Screen; this screen displays the customer’s loyalty card number, current earned points, and current awards balance.
Open the Account Details panel at the Customer Loyalty List page in Modern View; this page displays the customer’s cards and the programs for each, as well as the program types, account numbers, levels, and current balances for each program.
View loyalty cards and awards in Contact Center Order Entry, and redeem awards in Contact Center Order Entry.
The information that Order Administration sends to Customer Engagement includes the following:
| Variable | Description |
cardNumber |
The loyalty card number assigned to the customer whose loyalty and award information is retrieved from Customer Engagement. |
currencyCode |
The default currency defined in the Local Currency Code (A55) system control value. This system control value must be set to a valid currency code.. |
transactionStoreId |
The store ID associated with the loyalty program; this is the location defined in the Default Location for ORCE Integration (K69) system control value. If you do not define a location in the Default Location for Sales Download (K69) system control value, Customer Engagement uses the location defined in the Default Location ID system configuration setting. |
The getCardInquiry method returns a CardInquiryResponse class object. Customer Engagement sends the following information to Order Administration.
| Element | Description |
ResponseStatus |
date/time |
The date and time of the inquiry. |
Instrument The Instrument element contains card information. |
card number |
The loyalty card number assigned to the customer whose loyalty and award information you wish to review. |
card serial number |
The serial number assigned to the loyalty card in Customer Engagement. |
card expiration date |
The date the card expires, if any. |
Loyalty Account The LoyaltyAccount element contains the loyalty accounts associated with the card. |
loyalty account ID |
The ID for the loyalty account in Customer Engagement. |
loyalty program |
The ID and name of the loyalty program associated with the account in Customer Engagement. |
loyalty program level |
The ID and name of the current level of the loyalty program to which the loyalty account belongs. |
points balance |
The current points balance for the loyalty account. |
card inquiry points entry |
The current points for the loyalty card for the following types of points:
AwardAccount The AwardAccount element contains the award accounts associated with the card. |
award account ID |
The award account ID associated with the loyalty card in Customer Engagement. |
award program |
The ID and name of the award program in Customer Engagement. |
coupon list |
The award coupons associated with the loyalty card in Customer Engagement. For each coupon:
Customer |
customer ID |
The Customer Engagement customer ID associated with the loyalty card. |
Customer Engagement Loyalty Account Services v3.4 API
Order Administration calls the Customer Engagement Loyalty Account Services version 3.4 API to generate the following methods:
The system uses the value in the ORCE Organization Descriptor (L50) along with the ORCE_CUSTOMER_SERVICE_PREFIX and ORCE_LOYALTY_SERVICE_SUFFIX settings in Working with Customer Properties (PROP) to build the URL for communication with Customer Engagement.
Customer Engagement issuePoints Method
The issuePoints method issues points to the loyalty account specified and creates a retail transaction ID for the transaction.
When called? The system calls this method when you click OK on the Issue Loyalty Points Window.
loyalty account Id |
The loyalty account ID associated with the issued points. |
transaction store Id |
The store ID where the transaction was performed; this is the location defined in the Default Location for ORCE Integration (K69) system control value. If you do not define a location in the Default Location for Sales Download (K69) system control value, Customer Engagement uses the location defined in the Default Location ID system configuration setting. |
points amount |
The number of points being issued. |
client comments |
Informational comments associated with the issue points transaction. |
The issuePoints method returns a loyaltyActivity class object. Customer Engagement sends the following information to Order Administration.
account activity Id |
The Customer Engagement activity transaction number for issuing points to the loyalty card. |
account Id |
activity date/time |
The date and time when the activity occurred. |
activity typecode |
bonus points balance |
The bonus points balance at the time of the issue points transaction. |
earned points balance |
The earned points balance at the time of the issue points transaction. |
escrow points balance |
The escrow points balance at the time of the issue points transaction. |
escrow transferred flag |
Indicates whether escrow points were transferred as part of the issue points transaction. |
loyalty rule Id |
The ID for the loyalty rule used in the issue points transaction. |
LTD points balance |
The current life to date points balance for the account at the time of the issue points transaction. |
points amount |
The confirmed points amount issued to the loyalty card. |
points method typecode |
The code indicating the method uses for points calculations. |
points originally requested |
The number of points that were defined in the issue points transaction. |
retail transaction business date |
The business date when the issue points transaction occurred. |
YTD points balance |
The current year to date points balance for the account at the time of the issue points transaction. |
Customer Engagement getLoyaltyAccountHistory Method
The getLoyaltyAccountHistory method retrieves all of the loyalty points account activity for the loyalty account specified. This method is specific to the loyalty points transactions associated with the loyalty card and does not include award coupons.
when you select Loyalty History on the Display Loyalty Account panel for a program in Modern
View. All loyalty points activity returned in the Customer Engagement Loyalty Account History Response except Inquiry activity displays on the Display Loyalty Account History Screen.
If the number of records available in the Customer Engagement Award Account Services v3.1 API exceeds the maximum setting in Customer Engagement, a relateExceptionCode will be in the response with a value ofMAXIMUM_LOOKUP_RESULTS_ERROR and the response will not include any history. If this occurs, Order
Administration displays a message similar to the following, where 400 is the maximum setting defined in Customer Engagement: Max results exceeded of: 400.
card number |
The loyalty card number whose loyalty points account activity you wish to review. |
currency code |
The default currency defined in the Local Currency Code (A55) system control value. This system control value must be set to a valid currency code. |
history start date |
The start date of the loyalty points account activity to return in the Customer Engagement Loyalty Account History Response. The start date defaults to the current date minus 2 years in order to get 2 year’s worth of loyalty points account activity; for example, if the current date is 3/4/2024, the start date will be 3/4/2022. |
history end date |
The end date of the loyalty points account activity to return in the Customer Engagement Loyalty Account History Response. The end date defaults to the current date. |
The getLoyaltyAccountHistory method returns a CardInquiryResponse class object. Customer Engagement sends the following information to Order Administration.
CardInqResponseStatus The status of the inquiry response. |
date/time |
status |
CardInqInstrument Card information. |
card number |
The loyalty card number associated with the loyalty points account activity. |
CardInqLoyaltyAccount |
loyalty program |
The ID and name of the loyalty program associated with the account. |
points balance |
The current points balance for the account. |
LoyaltyActivityList A list of loyalty account activities performed. |
transaction type |
The type of transaction activity performed.
The Display Loyalty Account History Screen displays all types
of activity except |
number of points |
The amount of points that were applied as a negative or positive to the loyalty card. |
pending flag |
account activity ID |
The Customer Engagement assigned activity transaction number for the record. |
location ID |
The location ID where the transaction was performed. |
create user |
The ID of the user who performed the activity. |
update user |
The ID of the user who updated the activity. |
void flag |
Escrow points balance for the account at the time of the activity. |
Earned points balance for the account at the time of the activity. |
Bonus points balance for the account at the time of the activity. |
comments |
Informational comments associated with the activity. |
business date |
The business date on which the activity occurred. |
rule name |
The rule that governed the points in the activity. |
reference transaction ID |
The ID for the transaction referred to by the activity. |
retail transaction ID |
The retail transaction ID associated with the activity. |
CardInqCustomer The customer associated with the card. |
customer ID |
Order Administration calls the Customer Engagement Award Account Services version 1.2 API to generate the following methods:
- Customer Engagement issueCoupon Method
- Customer Engagement automaticRedeem Method
- Customer Engagement getAwardAccountHistory Method
The system uses the value in the ORCE Organization Descriptor (L50) along with the ORCE_CUSTOMER_SERVICE_PREFIX and ORCE_LOYALTY_AWARD_SERVICE_SUFFIX settings in Working with Customer Properties (PROP) to build the URL for communication with Customer Engagement.
The issueCoupon method issues an award coupon to the loyalty account specified and creates a retail transaction ID for the transaction.
When called? The system calls this method when you click OK on the Issue Loyalty Coupon Window or when you issue an award coupon in Modern View.
award account ID |
The award account ID associated with the loyalty card. |
store ID |
user ID |
card number |
The loyalty card number associated with the award coupon. |
currency ID |
The default currency defined in the A55 system control value. This system control value must be set to a valid currency code. |
amount |
The amount of the award coupon to issue to the loyalty card. |
expiration date |
The date the award coupon expires. |
comments |
Informational comments about the issued award coupon. |
The issueCoupon method returns an awardTransactionResult class object. Customer Engagement sends the following information to Order Administration.
award transaction ID |
The Customer Engagement activity transaction number for issuing an award coupon to the loyalty card. |
account ID |
The award account ID associated with the award coupon. |
amount |
The confirmed award coupon amount issued to the loyalty card. |
coupon ID |
The award coupon ID generated by Customer Engagement for the issued award coupon. |
expiration date |
The date when the award coupon expires. |
The automaticRedeem method automatically redeems award coupons for the specified amount and creates a retail transaction ID for the transaction. Award coupons with the closet expiration date are redeemed first.
When called? The system calls this method during the final order accept for an order that contains a loyalty award coupon discount in Classic View Order Entry or in Contact Center Order Entry; see Applying and Redeeming Customer Engagement Awards during Order Processing.
award account ID |
store ID |
user ID |
card number |
The loyalty card number to redeem the award coupon against. |
currency ID |
amount |
The amount of the award coupon to redeem against the loyalty card. |
comments |
Informational comments about the redeemed
award coupon. A message similar to the following defaults if the award
coupon was redeemed through the Order API: |
The automaticRedeem method returns a CardInquiryResponse class object. Customer Engagement sends the following information to Order Administration.
card number |
The loyalty card number redeemed against. |
loyalty program |
points balance |
award account ID |
The ID for the award account in Customer Engagement. |
award program |
The ID and name of the award program associated with the account in Customer Engagement. |
coupon amount |
The amount of awards that were applied as a negative or positive to the loyalty card. |
coupon ID |
The ID of the coupon associated with the award coupon activity. |
customerID |
The getAwardAccountHistory method retrieves all of the award coupon account activity for the loyalty account specified. This method is specific to the award coupon transactions associated with the loyalty card and does not include loyalty points.
When called? The system calls this method when you;
If the number of records available in the Customer Engagement Award Account History Response exceeds the maximum setting in Customer Engagement, a relateExceptionCode will be in the response with a value ofMAXIMUM_LOOKUP_RESULTS_ERROR and the response will not include any history. If this occurs, Order
card number |
The loyalty card number whose loyalty award coupon account activity you wish to review. |
currency code |
The start date of the loyalty award coupon account activity to return in the Customer Engagement Loyalty Account History Response. The start date defaults to the current date minus 2 years in order to get 2 year’s worth of loyalty points account activity; for example, if the current date is 3/4/2014, the start date will be 3/4/2012. |
history end date |
The end date of the loyalty award coupon account activity to return in the Customer Engagement Loyalty Account History Response. The end date defaults to the current date. |
The getAwardAccountHistory method returns a CardInquiryResponse. Customer Engagement sends the following information to Order Administration.
status |
card number |
The loyalty card number associated with the loyalty award coupon account activity. |
award account ID |
award program |
coupon amount |
ID |
transaction type |
types of activity except |
location ID |
create user |
The ID of the user that performed the activity. |
void flag |
The date when the activity occurred. |
activity amount |
requested amount |
