12 System Operations
Oracle Retail Merchandising Foundation Cloud Service (RMFCS) and Oracle Retail Pricing Cloud Service (RPCS) Integration
Overview: Use the integration with Oracle Retail Merchandising Foundation Cloud Service (RMFCS) to import item information.
The import from RMFCS also supports importing pricing information from Oracle Retail Pricing Cloud Service (RPCS). This import is also described below.
This integration will be deprecated in a future release. Importing Enterprise Foundation Data through Omnichannel Cloud Data Service (OCDS) can be used instead to import items and pricing.In this topic:
Data Flow from RMFCS and RPCS to Order Administration
If your company is configured for RMFCS integration for item creation and update, processing takes place as follows:
1.Import momzip file into file storage: Use the API to place the inbound momzip file from RMFCS in the FILE_STORAGE table. See Working with File Imports for background.
You cannot use Work with File Uploads (WUPL) to process the momzip file.About the momzip file: The momzip file must contain one or more pipe-delimited text files, each with the DAT extension, created from RMFCS. The momzip file itself is a compressed file.
Item information: The itemhdr DAT file contains the item information to import from RMFCS
into Order Administration. Note that not all fields in this file are
mapped into Order Administration. See RMFCS to OACS Mapping and RPCS to OACS Mapping for details.
Pricing information: RPCS provides two DAT files:
Regular price: The
REGPCDAT file includes regular pricing information for items. -
Clearance price: The
CLRPCDAT file includes clearance pricing for items.
Like the Itemhdr file, the two pricing files
from RPCS are pipe-delimited text files. If either or both of these
files are included in the momzip file, the file contents update the RI Item Upload Table (RIIUPP) and, ultimately,
the Item Offer and Item Price tables. Because no offer information
is mapped from RPCS, the offer code to use defaults from the RMS Item Upload Periodic Function. See RPCS to OACS Mapping for mapping details.
File naming: The periodic function identifies
DAT files containing item or pricing data by the file name. The file
from RMFCS needs to begin with itemhdr, while the
pricing files need to begin with REGPC or CLRPC. Each file needs to include the store ID assigned
in RMFCS.
For example, a file might be named itemhdr_20180702123456_1234_delta_50.dat, where 201807123456 is the date and time stamp, 1234 is the store ID, delta indicates
that the file includes only changed records, and 50 is the total number
of records in the file. Including the text delta in
the file name is informational; regardless of whether it is included,
processing the records works the same way.
Similarly, a pricing file name might be REGPC_20180702021616_1234.dat.
Any other files included in the momzip file are not used.
File names and suffixes are not case-sensitive. For example, either momzip or MOMZIP are acceptable and will not result in an error.2. Process records in momzip file and create RI Item Upload records: Once the momzip file is available in the FILE_STORAGE table, the RMSItem Upload periodic function can process the contents of the file and create records in the RI Item Upload Table (RIIUPP). The periodic function includes a parameter defining the store ID assigned in RMFCS, as well as specifying the Company number.
See RMS Item Upload Periodic Function for details on configuring the periodic function.
If there are multiple momzip files, the oldest file is processed.
When this step completes, an RIIUPP record is created for each eligible row in the DAT file, and displayed at the Work with File Upload Screen even though you cannot use this screen to upload import files from RMFCS or RPCS.
This preliminary step of creating the RI Item Upload records does not include all the field mapping that ultimately needs to take place when updating the target tables; instead, the mapping is completed during the next step in the process, when the target tables are updated.
3.Use RI Item Upload records to create or update items, offers, and prices: The RI Item Upload Translation Program and RI Item Upload Edit Program process the records in the RI Item Upload table, and use these records to create or update items, offers, and prices. You can begin these programs by selecting Process File at the Work with Retail Item Upload Screen, or by submitting the RIUPLD Function.
Configuration for RMFCS and RPCS Integrations
Configuration within Order Administration
The configuration required in Order Administration to support importing items from RMFCS and RPCS is described below.
System Control Values
The following system control values must be selected:
Important:
See Retail Integration (External System into Order Administration) Overview and Setup for background on the additional setup required to support retail item integration. If you do not complete this setup, the import will not be successful.
The following system control values must be unselected:
Since this information is not provided by RMFCS, the import will not be successful if the information is required.
Use Working with Periodic Functions (WPER) to set up the RMS Item Upload periodic function. If the function needs to run in more than one company, mapping from more than one store in RMFCS, you can name the function RMSZIPN, where N is a unique number. When setting up the function:
Set the Program name to PFRRMS.
Set the Parameter to the store ID assigned in RMFCS, and the default offer code in Order Administration, separated by an underscore. For example, if the store ID is 1234 and the default offer is OFR, set the Parameter to 1234_OFR.
The offer code is required for the import of pricing information from RPCS. If you set the parameter to just the store ID, such as 1234, but do not include the offer code, such as 1234_OFR, the Current Offer (A33) applies.
Select the Company Parameter flag.
RIUPLD Function
Use Working with Periodic Functions (WPER) to set up the RIUPLD periodic function, if it does not already exist. When setting up the function, set the Program name to PFR0084.
Periodic Process
Use Working with Periodic Processes (WPPR) to assign either or both of the periodic functions described above to a periodic process. The Company parameter is required to indicate the company where the records should be created or updated.
Additional Considerations for RMFCS Integration
Does not support SKUs: Since RMFCS does not support SKU’s, all items imported from RMFCS are non-SKU’d items.
Using RMFCS Item Level and Tran Level to determine whether to create or update an item: RMFCS uses a different hierarchy than Order Administration for multi-level items. The RMFCS hierarchy supports:
A level 1 item: For example, a picture frame that comes in only one finish and size.
A level 2 item: For example, an item group that includes a novelty tee shirt in sizes small, medium, and large. Level 1 is the tee shirt, while level 2 includes the sizes.
A level 3 item: For example, an item group that includes a polo shirt in red, blue, and yellow, and sizes small, medium, and large. Level 1 is the polo shirt, level 2 is the sizes, and level 3 is the colors.
The records in the itemhdr file that map
to items in Order Administration are identifiable by the fact
that the ItemLevel passed in the file is the same as the TranLevel.
If the ItemLevel and the TranLevel are different, the record is not
used to update the RIIUPP table in Order Administration.
Troubleshooting Information for the RMFCS Item and Pricing Import
If the process ends without populating the RIIUPP table, possible explanations include:
The momzip file was not found.
The number of columns in the DAT file was incorrect.
The RIIUPP table already contained records that need to be cleared before the process could run again.
When there is an error with the import, it is listed on the Work with File Upload Screen with a File Type of RIIUPP and a status of Error, and you can view the error description by selecting Action > View Error.
If the momzip file did not contain a DAT file containing the itemhdr data, the upload remains at the Work with File Upload Screen in Submitted status. To correct this situation, you need to delete the momzip file from the FILE_STORAGE table.
Mapping Item and Pricing Information into Order Administration
The item information that updates the RI Item Upload Table (RIIUPP) and ultimately updates the target tables, including information mapped from RMFCS, is described in the following table. The process creates record type 01 (Item/SKU) records in the table based on the information from RMFCS. See RI Item Upload Table (RIIUPP) for more information on the updated fields.
The file from RMFCS contains no null fields. A blank is passed for an alphanumeric field with no data, and a 0 is passed for a numeric field.
**DFLT ITEM? Certain fields default from the **DFLT ITEM Item/SKU, if one is configured. These fields are indicated below. This information defaults when the RI Item Upload Translation Program and RI Item Upload Edit Program run, using the information in the RI Item Upload table to update the target tables.
**DFTCHG Item? The **DFTCHG Item/SKU controls the update of existing items:
Any fields that are populated for the **DFTCHG item are not changed for an existing item that is passed from RMFCS.
And any fields that are not populated for the **DFTCHG item are eligible to be updated for an existing item that is passed from RMFCS.
See the **DFTCHG Item/SKU for more information.
See RPCS to OACS Mapping for information on how pricing information in the RI Item Upload Table (RIIUPP) is updated based on the data received from RTM.
Additional information from RMFCS: Additional information is included in the DAT files from RMFCS; however, only the fields that update the RI Item Upload Table (RIIUPP) are described in the following table.
Sample itemhdr row:
ITEMS|FULLHDR|1234|102900077|||N|N|1|1|Y|||||||||||||2CDQ|2222|5274|2222|5485|A|Item
102900077||Item 102900077||Y|N|1000|EA||||E|N|12.22|USD||USD|||N|N|N|N|N|ITEM|||||N||||N|N|Y|Y||||N|N|N|N||||||||N|N|
About unmapped item/SKU fields: Any item/SKU in Order Administration fields not listed below are not mapped from RMFCS. They are left blank if alphanumeric, or set to 0 if numeric.| Target Field | Value Used | Description/ Comments |
Item Updates |
Company |
Company number from the periodic process |
The periodic process set up for the RMS Item Upload periodic function should be set up to require the Company Parameter. |
Record Created Date |
Current date when record created |
Record Created Time |
Current time when record created |
Record Type |
01 |
Hard-coded. |
Request Type |
blank |
Since RMFCS does not indicate whether the record is an Add or a Change, Order Administration updates the record for the item if it exists. If no matching item exists, it creates a new item. |
Sequence # |
Sequential assigned number |
Assignment of sequence numbers starts at 1 and continues for the first 999 records in the upload file. After the first 999 records, the Record Created Time increases by 1 second, and sequential assignment begins again and again runs from 1 through 999. This pattern continues for all records in the upload file, so that each has a unique Record Created Time/Sequence # assignment. |
Key Type |
IT |
Hard-coded. |
Item |
RMFCS item code |
Rather than using item SKU fields in the same way as Order Administration, RMFCS uses a hierarchical system to identify the relationships between individual items. An item code in the import table creates or updates an item in Order Administration only if the item’s ItemLevel and TranLevel in RMFCS are the same. See Additional Considerations for RMFCS Integration for a discussion. |
SKU |
Blank |
Not used. See Additional Considerations for RMFCS Integration for a discussion. |
Status |
U |
Unprocessed. |
Processed Date |
Blank |
Populated through the RI Item Upload Process. |
Processed Time |
Blank |
Allow SKUs |
N |
Hard-coded. SKUs are not supported through the integration. |
Drop Ship |
Blank |
From the **DFLT ITEM Item/SKU; otherwise, unselected. |
Long SKU Style |
ItemParent |
If no ItemParent is passed, the item code is used as the Long SKU Style. |
Retail Style # |
Item |
The item code from RMFCS is used as the Retail Style #. |
Long SKU Vendor |
Subclass |
The Subclass from RMFCS is used as the Long SKU Vendor. |
Non-Inventory |
Blank |
From the **DFLT ITEM Item/SKU; otherwise, not selected. Note: Non-inventory items from RMFCS, indicated by a setting of N in the MerchandiseInd field, are not imported into Order Administration. |
Selling Qty |
1 |
Selling Weight |
0 |
From the **DFLT ITEM Item/SKU; otherwise, 0. |
Serial # Tracking |
N |
Not implemented in Order Administration. |
Ship Alone |
From ShipAloneInd |
When the ShipAloneInd from RMFCS is set to Y, the Ship Alone field is set to S; otherwise, the Ship Alone field is left blank. |
Allow % Discount? |
Blank |
From the **DFLT ITEM Item/SKU; otherwise, not selected. |
Oversize |
Blank |
Description |
ItemDesc |
From the ItemDesc in RMFCS. |
Exclude From Flex Pay |
Blank |
Royalty |
N |
Membership |
Blank |
Buyer |
Blank |
From the **DFLT ITEM Item/SKU; otherwise, blank. |
Item Class |
Blank |
Location Class |
Blank |
Class (Long SKU Class) |
Class |
The Class from RMFCS is used as the Long SKU Class. |
Department (Long SKU Department) |
Department |
The Department from RMFCS is used as the Long SKU Department. |
UOM (Unit of Measure) |
StandardUOM from RMFCS |
Needs to be a valid unit of measure in Order Administration, set up through Working with Units of Measure (WUOM). Note: Units of measure set up in RMFCS should not exceed 3 positions, since this is the maximum field length supported in Order Administration. |
Vendor # |
Blank |
Ship Via Code |
Blank |
Manufacturer Vendor |
Blank |
Entity Number |
Blank |
Season |
Blank |
Subscription |
Blank |
Height Override |
0 |
Length Override |
0 |
SKU Gift Certificate |
N |
Hard-coded. Not supported in Order Administration. |
Restrict Orders |
Blank |
VAT Exempt Flag |
Blank |
Suppress B/O Card |
Blank |
Returnable |
Blank |
Whs (Warehouse) |
From the **DFLT ITEM Item/SKU; otherwise, from the Default Warehouse (A04); otherwise, set to 0. |
Soldout Control Code |
Blank |
Defaults from the Default Soldout Control Code (D72). |
UOM Type |
Needs to match a unit of measure in Order Administration, set up through Working with Units of Measure (WUOM). |
OROB Eligible |
Selected. |
The offer and pricing information that updates the RI Item Upload Table (RIIUPP) and ultimately updates the target tables, including information mapped from RPCS, is described in the following table. The process creates record type 03 (Item Offer) and 05 (Item Price) records in the table based on the information from RPCS. See RI Item Upload Table (RIIUPP) for more information on the updated fields.
The file from RPCS contains no null fields. A blank is passed for an alphanumeric field with no data, and a 0 is passed for a numeric field.
See RMFCS to OACS Mapping for information on how item information in the Item table and related tables is updated based on the data received from RMFCS.
Additional information from RPCS: Additional information is included in the DAT files from RPCS. The files each include a header record (FHEAD) and a tail record (FTAIL), as well as a detail record (FDETL) for each item offer and price. However, only the fields that update the RI Item Upload Table (RIIUPP) are described in the following table.
Unmapped Item Offer fields: Any Item Offer or Item Price fields not listed in the following tables are not mapped from RMFCS. They are left blank if alphanumeric, or set to 0 if numeric.
Sample REGPC file contents:
FHEAD|1|REGPC|20180627021616|1234|S
FDETL|2|CRE|1001|101000122|20180404000000|1|16.75|EA|USD|0||||
FDETL|3|CRE|1002|101000132|20180405000000|1|16.75|EA|USD|0||||
FDETL|4|CRE|1003|101000123|20180627000000|1|16.75|EA|USD|0||||
FTAIL|5|3
Sample CLRPC file contents:
FHEAD|1|CLRPC|20180404021514|4241|S
FDETL|2|CRE|10002|101000126|20180404000000|6.85|EA|USD|
FDETL|3|CRE|10003|101000136|20180405000000|8.85|EA|USD|
FDETL|4|CRE|10004|101000135|20180404000000|7.85|EA|USD|
FTAIL|5|3
Item Offer Mapping from RPCS
Item Updates |
Company |
The periodic process set up for the RMS Item Upload Periodic Function should be set up to require the Company Parameter. |
Record Type |
03 |
Indicates Item Offer. Hard-coded. |
Request Type |
blank |
Since RPCS does not indicate whether the record is an Add or a Change, Order Administration updates the record for the item if it exists. If no matching item exists, it creates a new item. |
Sequence # |
Key Type |
IT |
Hard-coded. |
Item |
RMFCS item code |
The item to be updated with the Item Offer information. |
SKU |
Blank |
Status |
U |
Unprocessed. |
Processed Date |
Blank |
Processed Time |
Blank |
Offer for Item Offer |
Offer from periodic function |
The offer code defaults from the Parameter defined for the RMS Item Upload Periodic Function. If no offer code is specified for the periodic function, the Current Offer (A33) applies. |
Item Price Mapping from RPCS
The following mapping applies to both the REGPC (regular price) and CLRPC (clearance price) files from RPCS.
Item Updates |
Company |
Record Type |
05 |
Indicates Item Price. Hard-coded. |
Request Type |
blank |
Sequence # |
Key Type |
IT |
Hard-coded. |
Item |
RMFCS item code |
SKU |
Blank |
Status |
U |
Unprocessed. |
Processed Date |
Blank |
Processed Time |
Blank |
Effective Date |
RPCS Effective Date |
The date when the price becomes effective. |
Qty |
RPCS: Multi-Units |
The quantity required for the price break. In the case of the CLRPC file (clearance price), the quantity is hard-coded to 1. |
Price |
RPCS Multi-Unit Retail |
The item price. |
