9 Ship Order
Purpose: Use this screen to confirm shipment of a delivery order that is assigned to your current store location.
Available when? This screen is available by selecting Begin Shipping in the bottom right at the Ready to Ship screen, the View Order screen, or the View Full Order screen for a delivery order that has been picked but not yet fully shipped, and that is not currently Under Review.
Options at this screen
| Option | Procedure |
confirm shipment of all the items on the order using normal shipping |
When shipment is confirmed:
If an error is displayed: The screen might display
an error when you select Complete Shipping if there was a problem
communicating with the shipping service, or if the shipping address
is incorrect or incomplete. If the message indicates that there is
an issue with the shipping address, you can select the pencil icon
( If the status of the order lines have changed: A message indicates if the status of any of the lines to be shipped has changed, and are no longer eligible for shipment. This could occur if, for example, the customer has recently canceled the order. When this occurs, you return to the Ready to Ship screen. Packing slip needed? Depending on the configuration for your organization, the Packing Slip might not be generated automatically when you confirm shipment. If you need to print the packing slip, select View Packing Documents, as described below, before selecting Complete Shipment. |
confirm shipment of all the items on the order using manual shipment (or confirm shipment if normal shipping is not enabled) |
Note: Optionally, you can switch back to normal shipping,
if your current store location supports it, by selecting Revert
to Normal Shipping from More Options ( When shipment is confirmed:
( If the status of the order lines have changed: A message indicates if the status of any of the lines to be shipped has changed, and are no longer eligible for shipment. This could occur if, for example, the customer has recently canceled the order. When this occurs, you return to the Ready To Ship screen. |
confirm partial shipment of the order |
The option to confirm a partial shipment is available only if your organization supports it.
Note: Optionally, you can switch back to shipping the
full order by selecting Revert to Ship Full Order from More
edit the shipping address |
Optionally, select the pencil icon ( |
view packing documents |
Select View Packing Documents from
More Options ( |
| cancel the entire order |
Select Cancel Order from More Options
( You might cancel an order if the customer has indicated that they don’t want the order. Order Broker does not attempt to find another location for the order. |
| reject the entire order |
Select Reject Order from More Options
( You might reject any order if you don’t have the stock available to fulfill it. What happens when you reject: Order Broker sees if there is another location that can fulfill the order. |
| cancel an item |
Select Cancel Item from More Options ( You might cancel an item if the customer has indicated that they don’t want the item. Order Broker does not attempt to find another location for the item. |
| reject an item |
Select Reject Item from More Options ( You might reject an item if you don’t have the stock available to fulfill it. What happens when you reject: When you reject an item on a delivery order, Order Broker sees if there is another location that can fulfill the item. |
return to the previous screen |
Select X from the top right to return to the previous screen. |
Fields at this screen
| Fields | Description |
Order number |
The number or code identifying the order in the originating system. |
Status |
The order status indicated is Ready to Ship. |
| Number of units |
The total number of units on the order. |
| Fulfillment Type |
A fulfillment type of Delivery is indicated to the right.
The express icon ( |
Items: For each item on the order that is assigned to your current store location and ready to be shipped, the following information is displayed. Items on a delivery order that are assigned to a different store location are not displayed on this screen. You can review all order lines at the View Full Order screen. |
| Item description |
A description of the item. An image of the item may also be displayed. |
| Item code |
A code identifying the item. |
| Price |
The price of a single unit of the item. |
| Available Quantity |
The available quantity of the item after subtracting the quantity on any open orders, plus the quantity on the displayed order line. Since the quantity of the displayed order line is added to the calculated available quantity, the available quantity displayed for two order lines for the same item will differ if the order lines are for different quantities. For example, if the available quantity is 50, and the quantity on the order line is 5, the available quantity displayed is 55; however, if the quantity on the order line is 2, the available quantity displayed is 52. |
| Quantity Picked |
The current quantity of the order line that has been picked. |
Shipping Details: Use the following fields to enter information about the shipment. |
| Package Weight |
Enter the weight of the package if it has not defaulted from the order, or if it is incorrect. The unit of measure, such as grams (g), is indicated. |
| Box Size |
Select the box size for the shipment from the drop-down list. The defined dimensions of the selected box size are indicated in the Length, Width, and Height. Or select Irregular Size if you need to enter the length, width, and height. |
| Length |
The length of the box. Defaults from a defined box size, or you can enter the length if you select Irregular Size. The unit of measure, such as cm, is indicated. Note: If you are entering the length, the number you enter can’t be more than 99. |
| Width |
The width of the box. Defaults from a defined box size, or you can enter the width if you select Irregular Size. The unit of measure, such as cm, is indicated. Note: If you are entering the width, the number you enter can’t be more than 99. |
| Height |
The height of the box. Defaults from a defined box size, or you can enter the height if you select Irregular Size. The unit of measure, such as cm, is indicated. Note: If you are entering the height, the number you enter can’t be more than 99. |
| Carrier |
The default carrier to ship orders is displayed. Optionally, you can select a different carrier from the drop-down list. |
| Tracking Number |
If you are using manual shipping, you need to enter a tracking number. Otherwise, if you are using normal shipping, the tracking number is not displayed here, and will be assigned automatically. |
Order Details: Information about the customer and the placed location are displayed. |
| Ship To |
The shipping address for a delivery order. Might be the same as the sold-to address. Can include:
If the address has been updated in the originating system since the order was originally created, it isn’t automatically updated here. If needed, you can update the shipping address for a delivery order at the Edit Ship To Details window. |
| Sold To |
The sold-to customer’s address for a delivery order, if a separate shipping address was specified. Can include:
If the address has been updated in the originating system since the order was originally created, it isn’t automatically updated here. |
| Placed Location |
The code and description of the location where the order was placed. May represent another store location, the distribution center, or the web storefront. |
