About Till Options
Select this option for all functions that apply to a till in use by the register.
Figure 11-3 Till Options Menu
The Till Options menu has the following options:
Change Float - Select this option to change the amount of cash that remains in each till after the end count is performed. See Changing the Float Amount.
Foreign Currency Maint. - Select this option to update the exchange rate between the local currency and foreign currencies that are acceptable tenders. See Foreign Currency Maintenance.
No Sale - Select this option to perform a no sale transaction to open the cash drawer.
Refer to the Oracle Retail Xstore Point of Service User Guide for a step-by- step procedure describing the no sale transaction.
Paid In - Select this option to perform a paid in transaction. This option requires an attached till. See Performing Paid In/Paid Out Transactions.
Paid Out - Select this option to perform a paid out transaction. This option requires an attached till. See Performing Paid In/Paid Out Transactions.
Post Void - Select this option to perform a post void transaction. See Attaching a Cash Drawer Till for more information.
Tender Exchange - Select this option to perform a tender exchange transaction, which allows you to exchange one form of tender for another. For example, accept a customer's check for some amount and give them the same amount as cash.
Refer to the Oracle Retail Xstore Point of Service User Guide for a step-by- step procedure describing the tender exchange process.
