Add a Note
To add a note to a task:
Select the task in the Task List or the Awards tab in Customer Maintenance.
Click the task.
Use the up and down arrows to highlight the task, then press the Spacebar.
Click Add Note.
A note entry window opens.
Enter the note text.
Click OK.
The note is added to the task
