Edit a Task
To edit a task:
Select the task in the Task List or the Awards tab in Customer Maintenance:
Click the task.
Use the up and down arrows to highlight the task, then press the Spacebar.
Click Edit Task.
A task details window opens.
Make the necessary changes to the task:
Description - Description of the task.
Priority - Priority of the task.
Start Date - Date on which the task will begin.
End Date - Date by which the task must be finished.
Start Time - Time at which the task will begin.
End Time - Time at which the task must be finished.
If necessary, assign a customer to the task:
Click Assign Customer.
Xstore Point of Service opens a window prompting for customer search criteria.
Associate a Customer with the Transaction.
The customer is assigned to the task.
Click Save.
The note is added to the task.
