Create a Task
To create a task:
Click Add Task in the Task List or the Awards tab in Customer Maintenance.
Enter the task information:
Type - Type of task.
Description - Description of the task.
Priority - Priority of the task.
Start Date - Date on which the task will begin.
End Date - Date by which the task must be finished.
Start Time - Time at which the task will begin.
End Time - Time at which the task must be finished.
Visibility - The group that can view the task (Store, Employee Group, or Employee).
Employee Group visibility is not an option if you are using Customer Engagement to manage your tasks.
Assigned To - The employee group or employee to assign to the task. This field is not editable for tasks with Store visibility.
If Xstore Point of Service indicates the employee is not a valid Customer Engagement user, the employee does not exist in Customer Engagement.
If necessary, assign a customer to the task by performing the following:
Click Assign Customer. Xstore Point of Service opens a window prompting for customer search criteria.
Associate a Customer with the Transaction. The customer is assigned to the task.
Click Save.
This task is created and added to the Task List.
