Lock or Unlock a Register
Your system may be configured to automatically log out an associate after a specified period if there is no system activity. However, you may need to temporarily leave a register before that occurs. In that case, you can lock the register to prevent another person from using the system while you are away.
Lock a Register
Registers can be locked from the Register Login screen or the Register Sale screen:
Register Login Screen
To lock a register:
Click Manage Tills in the Register Login screen.
Do one of the following, depending upon the configuration of your system:
Enter your password and press Enter.
The Manage Tills menu opens.
Click Register Options.
Click Lock Register.
The system displays a message indicating that the system is now locked.
Unlock a Register
To unlock a register:
Enter your user ID in the Register Login field and press Enter.
Xstore Point of Service prompts for your password. Continue with Step 3.
Scan your finger on the fingerprint reader.
The register is unlocked.
