Opening an Order Broker Order
To search for an Order Broker order:
Click Extended Transaction in the Register Sale screen. See Figure 15-2.
Click Order.
If a customer is associated with the transaction:
If no customer is associated with the transaction, Xstore Point of Service prompts for order search criteria. Continue with Step 4.
Click Order Search.
Xstore Point of Service displays a search window.
Enter the search criteria.
Click Process.
If only one order matches the search criteria, Xstore Point of Service opens the order. The order is opened, and the transaction continues.
If more than one order matches the search criteria, Xstore Point of Service displays a list of orders. Continue with Step 6.
Select the order:
Click the item.
Use the up and down arrows to highlight the correct item and press the Spacebar.
Click OK.
Xstore Point of Service opens the order. Continue the transaction.
