Configuring Customer Displays
...continued from step 4
Pole Display is the only Customer Display type supported at this time.
At the Customer Display page, click Pole Display.
Figure 5-54 Customer Display Page
The current pole display message is shown in the Pole Message field. Edit the pole display message as needed:
Figure 5-55 Edit Pole Display Page
Pole Message - To edit the message text, type the new message. The maximum length is 40 characters.
Locale - If needed, select a translation locale and enter the message text for the locale.
A pole message is required for the default locale. A pole message is not required for other locales you may have set up.
Click Save.
