Configuring Xstore Registers for IDCS
To configure Xstore registers for IDCS follow the steps listed below:
Enroll one or all stores in an organization node with cloud services.
From the Oracle Retail Xstore Office menu, select System Management, then select Store Authorization Manager. From the Store Authorization Manager menu, select Store Authorization Manager. Select an organization node and press Next. The Store Enrollment Screen is displayed.
Figure D-2 Store Enrollment — Configure Registers for IDCS
Select Enroll to enroll the selected stores to communicate with Cloud Services. No connection details are required.
For more information on how to enroll stores with cloud services, see the Store Enrollment section in chapter System Management.
After the deployment of the store enrollment is complete, use the Personality Maintenance functionality to configure IDCS access for a service, for example Customer Engagement or Order Broker.
From the Oracle Retail Xstore Office menu, select Config Manager — Profile Management, or click the Profile Management link in the Configuration Manager panel. Form the Profile Management page, select Personality Maintenance add a new personality.
At the Base Features tab, enable IDCS access for a service.
Figure D-3 Personality Maintenance Screen — Base Features Enable IDCS
For more detailed information on how to enable IDCS access for a service, see the Personality Maintenance section in chapter Configurator.
The Xservices must be manually configured with the correct configuration path to use IDCS for the various services. Add the following entries to the
xservices.propertiesfile:-
For IDCS Access to Customer Engagement add
:idcs/relateto the config path base features. -
For IDCS Access to Order Broker add
:idcs/locateto the config path base features.
