Personality Maintenance
Use Personality Maintenance to group one or many Profile Group and Element combinations that will be used to define a store.
From the Oracle Retail Xstore Office menu, select Config Manager - Profile Management, or click the Profile Management link in the Configuration Manager panel.
From the Profile Management page (Figure 4-1), select Personality Maintenance.
At the Personality Maintenance page, add a new Personality or edit an existing one:
Figure 4-7 Personality Maintenance Page
To quickly find a Personality, enter text in the Description field. The list will be filtered to show the Personalities with the text in their descriptions.
If adding a new Personality:
Click Add New.
At the Edit Personality page, use the wizard to complete the information on each tab, then click Next. See Personality Setup Options for a list of Personality options.
Skip to step 4 to review your selections.
If editing an existing Personality:
Select the Personality in the list.
At the Personality Detail window, click Edit.
Complete the fields as required, then click Next. See Personality Setup Options for a list of Personality options.
Continue with step 4 to review your selections.
Review the Personality options you selected:
Figure 4-8 Personality Options Review
To save the Personality, click Save. The Personality is added to the list on the Personality Maintenance page.
To edit the Personality:
Click Previous to go back one page, or select a configuration option in the Edit Personality section in the left panel of the window.
After making your changes, click Save. The new Personality is added to the list on the Personality Maintenance page.
To discard the Personality, click Cancel. When prompted, click Yes to confirm you want to cancel Personality setup.
After completing Personality setup, Oracle Retail Xstore Office returns to the Personality Maintenance page.
To delete a Personality that has been created or updated, click the Delete icon associated with the Personality on the Personality Maintenance page.
When prompted, click Yes to confirm the deletion.
If a Personality has been assigned to a Store, it cannot be deleted.
This section describes the personality setup options.
General Information
Define the basic information for the Personality, then click Next.
Description - Enter the Personality identifier.
Comments - [OPTIONAL] Enter additional identifying information for the Personality.
Base Features
Enable and disable the Oracle Retail Xstore Point-of-Service base features that are active for this Personality, then click Next.
For more information on the available base features, see the xstore.config.path.base.features section in Appendix: Personality Maintenance and Config Paths.
Overrides
About the Profile Group and Element combinations:
The Profile Groups and Elements available here are created in Profile Maintenance. See Profile Maintenance for more information.
Only the Profile Groups with the type "Personality" are available in the drop-down list. (Profile Groups with the type "Landscape" are not available in Personality Maintenance.)
A <Store Specific> override entry is available by default in the drop-down list.
Select and prioritize the Profile Group and Element combinations:
Select the Profile Group for this Personality.
Select the Profile Element for this Personality.
Click Add Element.
Repeat steps a through c as needed to add all the Profile Group and Element combinations to this Personality.
If needed, select a Profile Group and Element combination row and use the up/ down arrows to change the priority. Elements at the top of the list have higher priority.
If needed, click the icon to remove the Profile Group and Element combination from the Personality.
Click Next.
