Store Personality Maintenance
Store Personalities are used to create the configuration paths specified in configPath.properties.
Store Personality Maintenance is where you assign the Personalities (created in Personality Maintenance) and Landscapes (created in Landscape Maintenance) to stores.
From the Oracle Retail Xstore Office menu, select Config Manager - Profile Management, or click the Profile Management link in the Configuration Manager panel.
From the Profile Management page (Figure 4-1), select Store Personality Maintenance.
[OPTIONAL] At the Store Personality Maintenance page, use the Filter Criteria and Find a Node search options to quickly find a store:
Figure 4-15 Store Personality Maintenance Page
To quickly find a store you can:
Select an option from the Filter Criteria drop-down list to filter the nodes displayed in the org hierarchy tree based on assigned personalities and landscapes. The following filter options are available:
No Filter (default): Select this option to remove any filters.
No Store Personality - Select this option to display only the stores that do not have store personalities assigned to them.
Personalities or Landscapes: All the personalities created on the Personalities Maintenance page are listed under the heading Personalities, and all the landscapes created on the Landscapes Maintenance page are listed under the heading Landscapes. Select a personality or landscape to display only the stores that have the selected personality or landscape assigned to them.
<OR>
In the Find a Node field, begin typing the node description to search for a specific node in the org hierarchy tree.
From the hierarchy tree, select a node to assign a Personality/Landscape pair.
Figure 4-16 Store Personality Maintenance Page - Store Node Selected
If you select a non-store node (for example District), all stores contained in that node will be affected by any change made to the personality and landscape. This will remove and replace any personality/landscapes that were previously assigned to stores within that node.
Click Edit to modify the personality/landscape assignments for the selected store.
At the Edit Store Personality window, select a Personality and a Landscape from the drop-down lists. Both a Personality and a Landscape are required.
Figure 4-17 Edit Sore Personality Window
Click Save to assign the selected Personality and Landscape to the store.
Figure 4-18 Store Personality Maintenance Page - Assignment Complete
See also Appendix: Personality Maintenance and Config Paths.
