Solution Architecture
This chapter provides an overview of the application architecture used by the integration, including:
Solution Overview
The technical aspects involved in the integration between Oracle Utilities Customer Cloud Service and Oracle Utilities Opower are:
Note: Email notifications are optional but are enabled by default. You can specify multiple email addresses in the “To Email” property by separating them with commas. For example: useremail1@company.com, useremail2@company.com.
The integration uses One-way Asynchronous and Synchronous patterns.
Synchronous Pattern
Synchronous OIC processing receives a request, transforms it, invokes the target, transforms the response, and replies. A global fault handler returns errors.
Synchronous integration pattern
The synchronous integration process:
  1. Receives a request message from the source application.
  2. Transforms the message from the source format to the target format. Lookups are used for data translations, if applicable.
  3. Invokes the target application with the request and waits for the response to come back.
  4. Transforms the response message from the target application to the source format. It sends a synchronous response/acknowledgment back to the source application.
  5. In case of any error, the global fault handler catches them and sends the transformed error message to the source application.
One-way Asynchronous Pattern
One-way OIC processing receives input, transforms the request, and invokes the target. Fault handling sends an email notification and records the error.
One-way asynchronous integration pattern
The one-way asynchronous integration process:
  3. Invokes the target application to send the request message.
  4. In case of any error, the global fault handler catches the error.
  5. An optional email notification is sent to the respective users as configured.
  6. The error instance can be re-submitted from Oracle Integration Cloud. Refer to the Error Handling section in Configuring Lookups, Error Handling, and Email Notifications for more details.
Solution Diagram
The following solution diagrams show the integration between Oracle Utilities Customer Cloud Service and Oracle Utilities Opower.
OIC connects Opower GraphQL APIs to CCS REST APIs for communications and transfers affordability files to the CCS content server for batch upload.
Solution Architecture Diagram
Integration Flows
The integration supports the following processes. Select a process to view its processing details and technical artifacts.
