Install the Adapter
These instructions describe the basic tasks required to install the
adapter. Refer to the server's installation or service manual for specific PCIe installation instructions.
Halt and power off the server.
Power off all of the peripherals connected to the server.
Open the server chassis.
Attach an antistatic wrist strap to the server chassis.
Remove the slot cover from the chassis.
Holding the adapter by the edges, align the card edge connector with the PCIe
slot.
Slide the adapter face plate into the small slot at the end of the PCIe
opening.
Applying even pressure at both corners of the adapter, push the adapter until
it is firmly seated in the slot.
| Caution -
Do not use excessive force when installing the adapter into the PCIe slot.
You might damage the adapter's PCIe connector. If the adapter does not seat
properly when you apply even pressure, remove the adapter, and carefully
reinstall it.
Detach the wrist strap and close the server.
Verify the installation.
Follow the instructions in the appropriate section:
