The mlxne driver for the Oracle Dual 25/100 Port Ethernet Adapter (Mellanox CX Adapter) is bundled in with the Oracle Linux operating system currently installed on your Oracle server. Use the following steps to view the installed version of the mlxne network driver.
# modinfo mlxne
The output should be similar to this:
filename: /lib/modules/4.14.35-1902.3.2.el7uek.x86_64/kernel/drivers/net/ethernet/mellanox/mlx5/core/mlxne.ko.xz version: 5.0-0 license: Dual BSD/GPL description: Mellanox Connect-IB, ConnectX-4 core driver author: Eli Cohen <eli@mellanox.com> srcversion: 986DA10F36F7BD4395E5964 alias: pci:v000015B3d0000A2D3sv*sd*bc*sc*i* alias: pci:v000015B3d0000A2D2sv*sd*bc*sc*i* alias: pci:v000015B3d0000101Csv*sd*bc*sc*i* alias: pci:v000015B3d0000101Bsv*sd*bc*sc*i* alias: pci:v000015B3d0000101Asv*sd*bc*sc*i* alias: pci:v000015B3d00001019sv*sd*bc*sc*i* alias: pci:v000015B3d00001018sv*sd*bc*sc*i* alias: pci:v000015B3d00001017sv*sd*bc*sc*i* alias: pci:v000015B3d00001016sv*sd*bc*sc*i* alias: pci:v000015B3d00001015sv*sd*bc*sc*i* alias: pci:v000015B3d00001014sv*sd*bc*sc*i* alias: pci:v000015B3d00001013sv*sd*bc*sc*i* alias: pci:v000015B3d00001012sv*sd*bc*sc*i* alias: pci:v000015B3d00001011sv*sd*bc*sc*i* depends: ptp,mlxfw retpoline: Y intree: Y name: mlxne vermagic: 4.14.35-1902.3.2.el7uek.x86_64 SMP mod_unload modversions
# ethtool -i enp59s0f0
driver: mlxne version: 5.0-0 firmware-version: 16.29.1414 (ORC0000000003) expansion-rom-version: bus-info: 0000:3b:00.0 supports-statistics: yes supports-test: yes supports-eeprom-access: no supports-register-dump: no supports-priv-flags: yes
