There is a known issue that causes Docker to timeout and fail if the IP firewall is running.
Workaround: On all nodes that run Docker (target nodes, and master nodes), turn off the firewall, if it is running. On Oracle Linux nodes, enter:
# systemctl stop firewalld # systemctl disable firewalld
Bug: 21889953, and 21795342
