The Murano engine cannot access the external network when deploying an application. When you deploy a Murano application, an error similar to the following is in the murano_engine logs:
murano_engine: ... getDefaultRouter'no external network found' % router_name
Workaround: Perform one of the following:
Create an external network named
ext-netand themurano-default-routeris automatically created and connected to the network, for example:$ neutron net-create ext-net --router:external
Create a router named
murano-default-routerand attach it to the external network.$ neutron router-create murano-default-router $ neutron router-gateway-set murano-default-router ext-net
Bug: 21976631
