If you try to deploy multiple OpenStack HA environments to the same subnet, the deployment may fail during the haproxy deployment step, with an error similar to:
TASK: [haproxy | Waiting for virtual IP to appear]
msg: Timeout when waiting for ip_address:3306
This is caused by having the same HA keepalived ID
(virtual_router_id) on the management
networks for each deployment. The default ID is
51. Each deployment requires a unique ID to
successfully deploy.
Workaround: For each
deployment, make sure you set the
virtual_router_id deployment parameter to
a unique ID, then (re)deploy.
On the master node, change the
virtual_router_idto a unique ID, for example:$ kollacli property set virtual_router_id
10On the master node, (re)deploy OpenStack services to the target nodes:
$ kollacli deploy
Bug: 22826409
