When you use the kollacli host destroy
--includedata command to destroy a node that runs the
Glance Image service (usually a controller node), the Glance
images are removed from the deployment but they remain on disk
in /var/lib/glance/images on the node.
You might want to monitor the
/var/lib/glance/images directory. Each
image file is named after the ID of the Glance image. Use either
the openstack image list or the
glance image list command to display a list
of image IDs. You can safely remove the image files that are not
listed by these commands.
Bug: 22909370
